Question about KitchenAid 22.0 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water
How do I turn on the ice maker on model kfcs22evms0? Thanks
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
Icemaker will not shut off
The ice maker has a pin plug in the back of most model refrigerators. Disconnect there if nothing works to turn it off. What is the model number of your refrigerator? Does the ice maker have a shut off arm that turns the ice maker off, switch or does your model refrigerator have an electronic eye that turns the ice maker off? Let me know what you find, Thanks Sea Breeze
Nov 15, 2012 | GALAXY Microsystems 25.4 cu. ft....
Ice maker is overflowing
If water continues to flow slowly after filling the water control valve for your model will need to be replaced=> 241734301 Water Inlet Valve
If ice maker simply over fills and then the water turns itself off then this points to a problem with the ice maker=> 5303918344 Ice Maker Assembly
I will be here to answer any questions you may have, Thanks Sea Breeze
Jul 12, 2012 | Kenmore Refrigerators
Ice maker will not make ice
It sounds like you might have a bad fill valve. There are several reasons that an ice-maker doesn't get water. If the freezer isn't cold enough, the ice-maker thermostat will not allow it cycle. There are two different styles of ice-makers. Pull the white cover off of the ice-maker, if you see two gears the you have one of the earlier models. Turn the smaller of the two gears counterclockwise slowly until the gears start to turn by themselves. Now if you do not have the two gears under the cover, then you have a modular ice-maker. There are several holes in the brown plate. Each hole will have a letter beside it. Jumper between the T and H holes until the ice-maker starts to turn by itself ( you should hear a click if you'll listen closely). Now that you ave cycled the ice-maker, check and see if there is water in the ice tray. If you still have no water then change your fill valve. If you do have water then its usually cheaper to replace the actual ice-maker. Be sure to check the temp of the freezer, most ice-makers will not cycle above 10F degrees. Most ice-makers are around $130. Most valves are around $50. I hope this helps you solve the NO ICE situation. Thanks for using fixya..com , please let me know how it goes, thanks mike
Jun 06, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Ice Maker stopped making ice - the unit is only 4 months old
Lets try this because I need the model nuber first befor giving the complete solution. Pour water into Ice maker tray turn on and let freeze. If Ice drops into ice bin and water does not come on the the dual water cotrol valve. If ice maker does nothing it wil be you ice maker or the grees F. See around door for model number, Thanks Sea Breeze
Apr 09, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Icemaker isn't working. Hot water pouring out
Most ice makers do have a defrost element below the ice maker. The problem you described is strange. I would like the model of the refrigerator and brand name. Unplug refrigerator and remove ice maker from freezer compartment now. If water continues to flow you may need the service line that feeds refrigerator turned off until I get your model number. Thanks, Sea Breeze
Feb 15, 2010 | Refrigerators
User manual for GE Ice Cream Maker Model 106765
Hi
Thanks for using FixYa. You can download the user manual for GE Ice Cream Maker Model 106765 from the following link—
GE Ice Cream Maker Model 106765 User Manual
Please do rate the solution.
Thanks
Rylee
Aug 22, 2009 | Gel Canister 106765 1.5 Quart Ice Cream...
Ice maker does not deliver ice cubes.
Hi
Thanks for using FixYa. Please check whether the ice maker has been turned off. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat and repair/replace if necessary. Although you have not provided me the specific model number of your Refrigerator, I have provided you the common solution in most of the models. If still the problem persists, then please tell me the model number of your unit to enable me to provide you with model specific information.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 22, 2009 | Refrigerators
ICE MAKER NOT WORKING ,MODEL #gss25lgma ww
The problem is most likely the water control valve on the rear of your refrigerator. You can test the ice maker by filling with water and let freeze. If ice dumps then the water valve must be replaced. Your model has 3 different choices of water control valves. If the ice maker does nothing but freeze the water and not cycle or dump the ice then I would say the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | GE Refrigerators
Samsung Model #RS2556SH ice maker
Not quite,maybe 80-90 if that.Think it maybe a water pressure problem. Thanks
Jun 11, 2008 | Samsung RM255LASH Side by Side...
KitchenAid 22.0 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water Logo
53 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
