TV has sound but no picture RCA ColorTrak 2000 P52150CP
TV made a slight pop and the picture went out. Gave no indication anything was wrong. Perfect picture, then black. Can hear the sound perfectly.
  • mdf5055 Jul 08, 2008
    i have an rca p52150cp big screen that has sound no picture and sometimes the picture will come in when its on it has a strong smell and the picture pops in and out can someone help me fix it
    Novelist:
    Champion:
  • 203 Answers
If I had a model # it would be helpful but my guess is the deflection circuit failed and a fuse opened in that circuit. Could be vertical or hoizontal circuit failure but either way you will need test equip. as well as solder/desolder equip. to repair it. If set is over 10-12 years old you may consider replacing set in this case Sorry I can't be more help.
Posted on Jun 02, 2008
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Mar 03, 2015 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
Rca colortrak 2000 manual
You may be able to get a manual by requesting it directly from RCA.
Jul 28, 2014 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
I have a RCA colortrak 2000 picture tube TV . There is one horizontal white line in the middle of the black screen
You have a vertical problem, caused by vertical deflections circuit failure, can involve a number of parts to fix.
Jan 03, 2011 | RCA Televison & Video
TV channel sound from a different channel
I just unplugged the tv from the power source and disconnected the cable connection and then reconnected them back after sometime. The TV started auto programming after turning on and that resolved the problem.
Oct 18, 2009 | RCA Televison & Video
Our 1991 RCA P52150CP rear projection TV has gradually been getting bright cloudy blue, slight haze around letters & shapes-(especially blue channel change headings) when first turned on and then it...
Hi
First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittant blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue crt board, or a problem in the RGB coming from the video jungle IC. A set this age, most likely will run you about 300 to 500 bucks to have this problem fixed, unless it is the picture tube.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | RCA P52926 52" Rear Projection Television
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
RCA Model P52150CP
Replace splitter RCA #205064, Q4101, U4101, C4102, C4118, C4108
Dec 12, 2007 | RCA P52926 52" Rear Projection Television
1987 RCA Colortrak 2000 Television
Line 1 is Channel 91, Line 2 is Channel 92 - you can select them directly using the remote
Sep 17, 2007 | Televison & Video
26in rca colortrak 2000
Very common problem The Highvoltage transformer and the horizontal output transistor has to be replaced. If you have no tv repair experience, this is not a repair for you. seek a professional. Should cost about 175 to 225 for this repair. Good Luck
Jul 12, 2006 | RCA F32450 32" TV
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
