Question about GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel
On my GE GSL25JFPABS refrigerator, the water will not shut off at thru door water maker. I have replaced the electric switch and that did not fix problem. Thanks Brian
SOURCE: GE Adora Side by Side Loose Handle
The cover plate comes off to exposed the screw that needs tightening. My husband just fixed ours as I was looking up how to fix it.
Posted on May 06, 2009
  • 2180 Answers
SOURCE: ice maker works fine in the door of my GE
could be the water valve located in the back of the fridge,there are two solenoids on the valve,one for water and the other for ice maker,you can disconnect the water line from the valve and have someone else draw some water,if the water doesn't spray out of valve you know the valve is bad or if you have a meter check it that way,if water does spray out you could have a frozen line in the door,try heating the area with hair dryer,hope this helps,have a great thanksgiving
Posted on Nov 26, 2009
woodchuck789
  • 4059 Answers
SOURCE: GE Profile refrigerator side by side, water and
The water inlet valve on the back where the water supply connects to the unit is stuck open. You may can clean the valve out and get it to closing or just replace it.
Posted on Dec 29, 2009
arikrom
  • 528 Answers
SOURCE: ge refrigerator water supply line freeze in door
there is a special kit for that to prevent it and your local repair can get you that its like metal foil that keep it from freeze up...
Posted on Jan 01, 2010
  • 71 Answers
SOURCE: Our GSL25JFPABS Side by side refrigerator door Water not working
water valve problem. behind the fridge. 3 or 4 screws .2 water lines. really simple.
Posted on Apr 01, 2010
How do I shut down the water flow to the ice maker
There are three ways.
1. Shut water off to the fridge via plumbing valve.
2. Lift arm on ice maker or use on/off switch depending on ice maker model.
3. Unplug ice maker wiring harness. It won't be able to call for water.
It depends on why you want the water off. A make and model of the fridge would help so I can give you a more specific answer.
Apr 05, 2016 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE GSCS3PGX ice maker not getting water
your dual stage water valve in the lower back behind the lower panel on the right side has a bad solenoid on the water side especially if you still get water to the door where the ice comes out,check its continuity,if its open or very high replace it,another test is,if you have compression screw on fittings reverse them and press the water fill switch on the door,if you then get water at the ice maker then for sure the valve solenoid is bad
Jul 13, 2012 | General Electric GE GSCS3PGX (22.6 cu....
Water thru the door does not work
First, is your ice maker making ice normally? If it is then you have water. If it isn't then it might be time to replace the water filter! If the ice maker IS working then it has to be either the dual water valve solenoid or the switch.
Jun 16, 2011 | GE Refrigerators
Hi my ice maker is not working
i must ask all questions. 1st is the water connected and did someone shut it off? allot of ice makers have a shut off switch inside the freezer that shuts off automatically when the ice catcher is full? look at your manual to see if it has any other suggestion if not contact me again
May 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile water pouring from ice maker
shut off the water to the unit and sounds like either the disp switch is stuck or the water valve faulty.
Apr 02, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice mker does not make ice
There are several causes of this.
Here is a list to check. Some of this may seem silly, but follow it through.
1 Water supply to back of fridge is shut off.
2 Tube that supplies water is pinched or kinked closed. Similar to a Kinked garden hose.
3 Solenoid valve (electric valve that opens and closes that supplies water to ice maker tray has failed)
4 Solenoid valve does not seal completely allowing water to seep past it. If this is the case the tube inside the freezer compartment will have a solid piece of ice in it which prevents water from going into the ice make. (very common cause of failure) Take very close look at the tube. Usually it can be removed and reinserted fairly easily. You may possibly have to remove the Ice maker. That involves more work, but not a great deal. Let me know if you need to remove it and I'll write you a procedure.
5 Ice maker feeler arm up (crescent shaped cube style of ice maker) which shuts the ice maker off.
6 Switch inside Ice Maker that controls fill valve failed. Or other parts in it failed. Replace ice maker. (usually costs less that getting it repaired)
7 County did not pay water bill to the state, and they shut off your water to collect.
(Rare)
I hope this helps. As it happens to be new years eve. Don't let this ruin it in any way. Get a bag
of Ice at the local store and have a HAPPY NEW YEAR
Best, Mark
Jan 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Mar 31, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE model GSH25JFTACC ice maker not working
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE side by side with ice and water in door
This is a problem with my GE side by side also. It only happens occassionally and there doesn't seem to be any fix. I've had GE repair service here more than once. It seems that the insulation in the door is insufficient to keep the water line from freezing up. Small wonder GE is part of this awful financial mess.
Dec 17, 2008 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel Logo
76 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
