Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool cabrio model # wtw6300sw1 will not spin!! It violently knocks all inside the cabinet and then throws the "UL" code. Tried cleaning and regreasing the four white ball joints in each corner and it still knocks and throws the "UL" code. HELP!!!
  • ohsoblest Oct 15, 2010
    rods have been checked as well and i have also ran a cycle without any clothes in the machine. It is still knocking and throwing the code.
    President:
  • 1,554 Answers
Redistribute the load to make sure it is balanced or run a spin cycle without load then see how the cycle works. The next thing to check are the suspension rods. Those are the rods that connect to the four white ball joints and the tub. The rods and springs should be intact and the assembly must be properly attached to the tub.
Post back the result of the inspection for further troubleshooting advise if necessary. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 14, 2010
  • 2 more comments
  • Jahn27
    Jahn27 Oct 15, 2010
    There are no other possible reason for the unbalanced condition except the bearings. The only viable solution then is replacing both the tub and the basket bearings.
  • Jahn27
    Jahn27 Oct 21, 2010
    Take
    the basket out and check the balance rings for water accumulation.
    Punch small holes through the balance rings to drain the water if
    there's any.
  • Jahn27
    Jahn27 Oct 21, 2010
    Take
    there's any.
  • Jahn27
    Jahn27 Oct 21, 2010
    Take
    there's any.
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6300sw1 agitator moves clockwise no counterclockise mov
This sounds like the dogs need replaced in the agitator. It's relatively easy and inexpensive to do.
Feb 11, 2010 | Whirlpool LSR5132PQ Top Load Washer
The time display section indicated a code UL instead of the time left on the washing cycle. What does this code mean
keep getting a ul code and machine barrel knocks back and forth in the washer on spin cycle until the ul comes up. Cannot get it to quit. What is the problem?
Thanks
Aug 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
462 people viewed this question
Dan Webster
Dan Webster
Sal De
