Question about Raymond Weil Tango 5560-STP-00328 Wrist Watch
Watch strap for tango clasp where it fastens on to the bracelet tubes come off.
    Scholar:
  • 101 Answers
This is an easy fix that can be done by a quality watch maker o jewelery repair shop , should cost no more than 10-20 dollars. All you need to do is bring it in and tell them that you need to have the clasp riveted. Its just a pin of sorts that has come undone. Look and see if there is a fast fix in your area they are usually very affordable and do the repair as you wait.
http://www.fastfix.com/
Posted on Oct 15, 2010
Omega 196.0167 cal 1342
The watch part number and a knowledgeable watch maker will provide the correct bracelet. If you WANT a leather strap most models can accept one - unless the case is sculpted to integrate seamlessly with the bracelet, in which case you may not be able to insert the spring bars that are necessary to mount the strap.
Sep 09, 2012 | Omega Watches
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
HOW OPEN INVICTA WATCH CLASP
Look at this video
https://www.youtube.com/watch?v=dkAoxVYtjXQ
you'll see the clasp as it look s when open. You need to hold the strap and clasp near one side of the 'join' while pulling the upper part of the strap away from the clasp on the other side.
Jan 11, 2012 | Invicta Square Angel Diamond Stainless...
Its too big to fit my hand good but also i cannot shorten it enouph so it can fit me without being extremely tight. Is there an alternate way to shorten it. I noticed 4 holes where the clasp is and was...
Some clasps have holes in them to allow you to adjust the straps in smaller steps than removing links.
It sounds as though yours in one of these.
The pins are spring loaded just like the ones used to fasten the strap to the lugs of the watch, so you can apply a probe to one end of the pin with one hand, while applying a gentle force in the direction you wish the strap to go with the other hand.
Then do the same with the other side and repeat as needed.
Jan 05, 2011 | Breitling Bentley 6.75 A4436212.G573.970A...
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
The spring in the clasp has broken so the watch band will not stay closed. How can I fix this problem?
replace clasp is the best option..if clasp has 2 buttons on it these can be a easy fix but they always break again so i would replace clasp section or even all the bracelet for the watch .you will need model and serial numbers of the watch then try manufacture or ebay or a repairer
Mar 25, 2010 | Watches
The folding deployment clasp on the bracelet/strap for my Tag 1000 series ladies watch has broken. Might a replacement clasp from any of the current tag models fit?
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Oct 17, 2009 | Watches
I have a rectangular faced Raymond Weil Tango. Unfortunately it was dropped resulting in the clasp breaking. My question is how much will it cost to repair or replace ?
is that watch has leather strap or matel,
raymond weil very customized on there watches, some time we order from them parts
and some parts avaliable from out sources as well best answer can be told if we see it, or send me a model number should be on the back of it or picture of it
at
AmFix Jeweley & Watch Repair
203 N. LaSalle St
chicago, IL 60601
312 641 7000
email : info@goamfix.com
www.goamfix.com
Aug 24, 2009 | Raymond Weil Watches Tradition 18K Gold...
How to fasten a Skagen watch?
Hi there. Insert the mesh strap inside the hole and secure with the hook and clip fastening with a foldover security clasp.
Hope this one helps.
May 16, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
Watch band missing link
Hi lovingdesert ,the only thing you do is go to a service center for watch,if they have clasp like of your Anne Klein,maybe they have an extra. sometimes customer leave thier adjusted clasp. or go to Anne Klein site,and order an extra clasp.
Jun 17, 2008 | Watches
Raymond Weil Tango 5560-STP-00328 Wrist Watch Logo
393 people viewed this question
Top Raymond Weil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Raymond Weil Watch Expert? Answer questions, earn points and help others
