Question about Sony KP-57WS510 57" Rear Projection HDTV
My TV doesn't turn on at all
There is power in the house, but when I try to turn on the TV, nothing happens. I've tried manually and with the remote, and there is no response. No clicking sounds eithere. Can you tell me how to troubleshoot the power supply, or should I start with that. I thought that could be it, since it is the common problem in a computer with a similar issue.
  • gi12fly Jul 03, 2008
    I have a problem much the same. When I turn my Sony KP-57ws510 on nothing happens except the tv clicks and the red power light flashes.
    The owners manual says to refer to an authorized service center for assistance.
How many times does the red light flash?
Posted on Aug 25, 2008
Black screen red diode blinks
unplug the set for a while then try it
Nov 09, 2013 | Samsung Televison & Video
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
When my tv is powered on, it displays the device menu and continues scrolling through it, but will do NOTHING else. I've tried to reset, and nothing. The tv will not respond to the remote at all.
A suggestion here: If possible to remove front speaker grill and inspection plate that should be behind it---locate the bundle of wires that comes down from front keyboard with the buttons and follow it to the right and down---should be one or two plugs in-line--------disconnect them with the set off and power set back up with remote.
If the problem is gone you have a bad micro-switch on the front of the set------buttons on the keyboard there have priority over the remote---hence you cannot if the problem is there stop it with the remote or do anything for that matter.
Let me know what happens and I will suggest options.
May 31, 2012 | Televison & Video
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
Hitachi 60UX58B will not turn on
I think there could have been a power surge... ask the repairman if the power supply is blown. :)
Jun 18, 2008 | Hitachi 60UX58B 60" Rear Projection...
My Mitsu WD-62628 will not turn on
It is probably by coinsidence that the set has failed. I doubt it was from the house cleaner. The set most likely failed on its own. The power supply is a common fault in most LCD screens when they fail. Sometimes a failure can occure on any of the other boards, and thus cause a fault in the power supply.
Jerry G.
Apr 16, 2008 | Televison & Video
Sony KP-57WS510 57" Rear Projection HDTV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
