Question about GE Kitchen Ranges
Electric range flat top slide in-model #J SP42B0K4BB; serial #ML255463Q; started beeping with F7 56 flashing on display. Turned it off a couple of times and then turned off power a couple times to no avail.
  • 5911 Answers
The F1 and constant beeping is an error code indicating that your electronic control board (clock/timer) is defective. The fault cannot be reset and the control board must be replaced. This can be an expensive repair if your range is no longer covered by a warranty or service plan. The cost to buy a new control board can be in the neighborhood of about $200. Sorry...but I do hope this helps you.
Posted on May 12, 2007
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
  • 833 Answers
SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Posted on Dec 13, 2007
  • 5911 Answers
SOURCE: F7 error message on all screens with beeps
F7 for a Fridgidaire Range indicates a failure with the electronic Range Control (ERC). Unfortunately when these fault codes pop up, the electronic boards must be replaced. The part number for yours is 937801 and costs about $190. Is it possible you may have gotten cleaner on the board or possibly shorted out the buttons? Is your range still covered under a warranty? Double check your paperwork and see if the electronics are covered for an extended period beyond the normal limited warranty you get when you purchase a new appliance. Post back with comments and/or questions if you wish to repair the range. I hope this helps you.
Posted on Jan 29, 2008
SOURCE: whirlpool Electric range model RF386
I had the f5 code displaying on my range also. When I read your comment that power surges can do strange things, I just tried unplugging the range then plugging back in and it cleared the code.
Thank you Tory
Posted on Feb 03, 2008
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it '
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ... > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
My oven was set to self clean. It got extremely hot and the it began beeping and flashing F1. I turned the circuit off, because I wasn't sure if it meant "Fire". So is it ok to turn the circuit...
Frigidaire's slide-in ovens feature an electronic oven controller, which serves to monitor and diagnose most electrical problems within the oven. If any of the oven's electrical systems fail, the controller will prevent the oven from functioning and will display a flashing "F" code on the oven's digital display and produce a beeping sound. To stop the beeping and clear the display, press the "STOP/CLEAR" button on the oven's control panel. Many times, the problem can be remedied by simply resetting the oven's controls. First, turn all of the oven's control knobs to the "Off" position, then allow the oven to cool to room temperature. If, after turning the oven on again, the "F" code still displays on the digital display, contact Frigidaire, as the wiring is likely to be defective.
Dec 06, 2010 | Frigidaire FEF352 Electric Kitchen Range
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Kenmore glass top
Your range was actually built by Whirlpool. the first 3 digits of the serial number determine who it was manufactured by.
It's possible that a battery somewhere is running low. This battery would be for the clock and timer.
See if you can find the service sticker and find the model nnumber - it would most likely be a couple of letters and some numbers. If you're from the US, you may be able to find a manual here:
If you're from the UK, it'll be here:
Please let me know how you get on.
Jun 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn-air probe won't shut off
mine did the same thing kept beeping and flashing prb, solution was it was mounted very close to the frame of wall and house must of shifted causing the wires on the outside to make contact with each other. adjusted the unit and beeping stopped .
Dec 23, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness.
Above says this is a Jenn-Air range. If so this is what f2 means. If you have a different brand let me know.
Nov 06, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Stove controls beeping and flashing "Probe"
Most likely oven sensor / probe is the problem. It can be tested with an ohm meter. Not sure about your model, but most should read around 1100 ohms at room temperature. If there's a tech sheet somewhere on your unit, it should tell you.
Sep 23, 2017 | Jenn-Air SCE30600 Slide-In Electric...
Kitchen Ranges Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
