Question about Canon imageCLASS D880 All-In-One Laser Printer
Paper jam in exit area. unable to access from either end
  • 24 Answers
Repair men.
Bernie
Posted on Oct 14, 2010
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Exit jam
have the machine perform a paper path test with just 1 copy to see if this jams then have it path test 5 prints to see when it jams- if its only jamming when more than one sheet is being printed then the fault lies with the paper pick up ( you may notice a longer delay for first print)
the machine will attemp to feed three times before failing as a jam
if the machine is printing more than one sheet then the jam appears just before the tail end of the first print exits the fuser (fixing Unit).
clean or replace the feed rollers.
if the jam happens on every print and the code is 13:02/3
then paper pass sensor arm 2 has stuck (look on you tube to resolve this search for lj4200 13:02 jam)
hope this helps- if you are still unable to get the machine working and your willing to pay then I would suggest Belmonte Buisiness machines
are a good company to deal with they are on 0161 480 5556 and can call out anywhere in the UK
Jan 26, 2014 | HP LaserJet 4250n Printer
My Brother Intellifax 5750e has paper jam issue. The paper jam sign will not go away. I took out the paper that was jammed. Still problem.
take your drum unit/toner out and close door to see if "jam" goes away. if so, look closely on bottom of drum unit in the middle. may be a scrap caught in there. if jam doesn't go away, you may have a piece caught in the fuser which is just b4 paper exits and that area is not easily accessible w/o tearing machine down.
good luck,
razors
Jul 28, 2011 | Brother IntelliFAX 5750e Laser Fax
I have a paper jam. Is there a paper feeder button or anything I can do to get the paper out. I have already taken out the paper tray, toner cartridge and opened the back and can barely see the paper. I...
To access possible paper jams areas, please click the link http://bit.ly/jtehCY and then go to page 69.
The manual shows the path the paper travels through the printer and the options. The path varies depending on the paper source and paper exit selection (output bin). The jam areas are also shown on the pages.
For further assistance, please contact Lexmark Technical Support.
Jun 30, 2011 | Lexmark Optra T610 Laser Printer
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
Mar 12, 2010 | OKI B4350 Laser Printer
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
I have a peice of paper jam in the output area of the imagerunner 1670, but the machine dosn't open to allow access to this area. how do i get the paper jam resolved.
Your jam is in the fuser section of the machine. Unfortunately this area this area is not for users to access. You will need to remove covers to get to the fuser unit. You may be able to access the paper by removing the whole drum unit (make sure you remove the toner cartridge first). Then look into the machine to the left. You may see the tail end of the document for removal. Otherwise, you will eed a service manual to dis-assemble it yourself.
IR1600 Service Manual
May 05, 2009 | Canon ImageRUNNER 1670F Copier
2 pieces are jammed and I can not find access to remove
Is the paper jam in the fixing unit? The Hot area before the paper comes out? If so, I believe if you are looking at the exit section to the rear of the copier there should be a same Green lever that you can move and it will release the preasure of the fixing unit. The only bad news of jams in the fixing unit is if you have any pieces of Black plastic that have came out of the copier, you may have to change the fixing film.
Mar 19, 2009 | Office Equipment & Supplies
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
Canon imageCLASS D880 All-In-One Laser Printer Logo
93 people viewed this question
old marine
old marine
