Question about Bryant Heating & Cooling
I am looking for a part on a Brant boiler that is at least 50 yrs. old
    Master:
  • 571 Answers
That's what the internet is for. Ask a question, and I will try to answer.
Posted on Dec 06, 2013
Leaking water, losing pressure and locking out - this boiler is 9 years old and recently kept losing pressure and then locking out.
9 yrs old its like anything else depends on maintenance and quality of unit --not safe since if safety doesnt shut down unit much more damage can occur
Sep 21, 2016 | Water Water Heaters
AMTROL WH7P-41 GAL TANK. 12 YRS OLD. BOILER PRESSURE IS INCREASING ABOVE 30PSI, AND DUMPING SMALL AMOUTS OF WATER FROM RELIEF VALVE ON BOILER. Do I replace coil?, or buy a new tank? Thank you
do you have a pressure tank as part of your water heater and water pipes? if yes, check to make sure tank pressure matches your incoming water pressure from your municipal hook up
Aug 18, 2015 | Amtrol Water Heaters
Ignition at Orifice
The gas control valve is passing . It will need a replacement.
Mar 10, 2014 | Water Heaters
What does error codes e34 and d65 mean on ariston boilers
You need to service the boiler and more likely to remove the restriction ring in flue, as only serving not always work or work only for short period, as boiler get older it is struggle to move exhaust gases out from burning chamber so it need good clean for fan, heat exchange , and there is restriction ring just befor L bow which need to remove so gases can flow better.
Jan 16, 2012 | Water Heaters
Electric dryer tumbles but does not dry clothes on any setting. dryer is only 4 yrs old.
Heating element has gone bad. You need to unplug unit. remove back, then find heating element and remove it. Look for what looks like broken springs, if found replace element. 99% of electric dryers not drying are the heating element. Cost around $50
Sep 28, 2010 | Dryers
Ariston Micro genus 11 Only getting hot water no central heating
Check the heat exchanger. Often they and gummed up.& you will have to try & flush it out or replace. If this model has the cylindrical type, they are pigs to do.
If this machine is 10 yrs old or more, you might find it better in the long run to have a new boiler
Just a thought, but I assume that the valves on the 3/4 " central heating pipes are turned on
Parts to look forward to later - fan £80 - pump £65 - heat exchanger £110 - diverter valve £65 - pressure relief valve £45
Mar 14, 2010 | Water Heaters
Amtrol 41 hot water maker :not working when calling for hot water,contols are on showing temp,but tank is cold.oil fired boiler is fine,the whole system is 5 yrs old.
The problem is probably with the circulator pump or the zone valve, which ever way your water circulating from the boiler is controled.
The water needs to be moved through the boiler and the coils in the Hot water maker to heat water. If this is not happening then no water will be heated.
Check for power and then is the pump is running or the zone valve opening.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 21, 2009 | Dishwashers
Static on 50
WHAT COLOR ARE THE SPARKLES? IF RED , BLUE AND GREEN, THEN IT NEEDS TO HAVE THE PANEL VOLTAGES ADJUSTED
Dec 08, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Heating & Cooling Logo
19 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
