I have a 13" Macbook running 10.5 that is having major problems connecting to wireless networks. I have a Macbook Pro that is not having these problems so I know the router is configured properly. Can I get a usb wireless card and use that instead of the builtin airport?
-   My macbook no longer is able to connect wirelessly to my router unless it is right next to it. all of my other computers have no problem finding the connection. This just started out of the blue.-   Guest
Mar 23, 2009
-   macbookpro will not connect to airport express.....nothing ..not found yadayadayada,,
-   Guest
you should try a software update first along with a PRAM and SMC update (hold the power button down when the computer is off for 15 seconds-it will beep. immediately after that hold down the Apple, option, P and R keys simultaneously until the computer reboots and chimes 3 times)
Was this helpful?
Yes
No
Popular Solutions for Apple Customized 13 MacBook
Apple Customized 13 MacBook Notebook Computer Z0EU00016 PC...
My LG 405 has the following problem of display 1. (separation of 4 box in the screen with no...
(More)
My LG 405 has the following problem of display 1. (separation of 4 box in the screen with no virualizaton in 3, and sometimes can't boot into windows and hang in a 4 box screen) 2. continuous reboot without log into window All problem exist esp after window Vista update
when i right click on the yahoo messenger icon, i left click on the 'open' option. Nothing happens....
(More)
when i right click on the yahoo messenger icon, i left click on the 'open' option. Nothing happens. Yahoo messenger will not open. Do you know why this is? When this happened initially, I deleted the programme from my computer. I then downloaded the newer version but still nothing happened when i tried to open yahoo messenger. I then rebooted the laptop and tried to open yahoo messenger version 10 again, but it still did not open.
Sony VGN-A790, 17? 1920x1200, ATI 600x (256MB) screen went dark when I connected a digital external...
(More)
Sony VGN-A790, 17? 1920x1200, ATI 600x (256MB) screen went dark when I connected a digital external monitor, worked fine with an analog. Any external monitor works. primary is so dark it looks blank unless you look at an angle. Occasionally it blinks with normal contrast then goes dark again. ati had a brief web note stating connecting a digital monitor & screen going blank was a known problem without solution. tried everything except reformatting the hard drive. could this be mechanical or voltage problem? Changing graphic cards? I hate to toss a 1920x1200 17?
I have a custom laptop built by ''I Buy Power'' I have been searching for a way to update the BIOS....
(More)
I have a custom laptop built by ''I Buy Power'' I have been searching for a way to update the BIOS. Windows and the BIOS is reporting the cpu speed as 800Mhz (never any higher)it is an AMD athlon 64 3400+ capable of 2.2Ghz. The mother board is a ''Hannstar J MV-4 94V-0 0443'' (all I could find written on it) it has an AMI BIOS ver 08.00.11 and an SiS chip set. The numbers at startup are ''63-0100-000001-00101111-090604-sis755-258ka000-y2kc'' Please if you can help me find a BIOS update or another fix to get the cpu to run correctly I would be VERY grateful.
