Question about Whirlpool Dishwashers
I have a Whirlpool Dishwasher, model DUC600, serial # FS2202628. It suddenly stopped working and "clean" light is flashing. I turned the power off, hoping to reset it but the light is still flashing. Can you give me some direction? If it's a component gone bad, I can replace it if you can tell me which one. Thanks! Joe
  • 65 Answers
SOURCE: Whirlpool dishwasher not working
igsanders.. that is a heater fault code. toggle between heated dry and normal until all light light up . press cancel. now ensure door closes without striking cabinet and the unit is level. this fault normally has nothing to do with the heater but rather the nuetral to the door switch which it shares with the heater.it will now operate again.
Posted on Feb 16, 2008
dutchman05
  • 487 Answers
SOURCE: problem with whirlpool dishwasher ADG957
Continuous flash with no pause is a Faulty NTC (temperature sensor)
Or according to whirlpool it might be that your keys are syticking.
Posted on May 07, 2008
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
SOURCE: whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Posted on Oct 21, 2008
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
Dishwasher Asko 1986 suddenly stopped working
Also is mainly a control board's
Did you have a power outage or power surge?
Need model
Oct 08, 2016 | Asko Dishwashers
My dishwasher will not start the heated dry light flashes constantly
Hello Daneil, we're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool 24 in. DP940PWP Free-standing...
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Whirlpool Gold Quiet Partner Model # GU980SCGQ2 The dishwasher normal light flashes on and off continually. The dishwasher won't stop cycling now, everything seems to work normally other than it won't...
Dlc737, We apologize for your concerns with your Dishwasher. If you have tried to reset from the breaker and it has not fixed the problem then we would recommend scheduling service. We would be happy to assist you further. Can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?We would be happy to assist you further.
Jun 09, 2017 | Whirlpool 24 in. GU980SCG Built-in...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Nov 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool from ikea DWF415
hazman, depending on your serial number, this model has a bunch of service issues. Everything from the motor rework to the heating element. Sounds like your issue has to do with the heating element. If the dishwasher does not detect a 4 degrees temp. rise in the water in will go into this fault. They have redesigned the board to bypass this fault in later models. Since I don't have a serial number I can't tell if you have one of the affected models, but I assume so. I would call Whirlpool and inquire about any service flashes they have on this dishwasher, you may be covered. Otherwise you would have to do some tests to determine the cause, starting with the heating element. I believe you can clear the fault by pressing these keys in this order: high temp-air dry-high temp-air dry. four key presses...this should put it in the automatic test mode. Let it do it's thing and the fault should clear. For more info on your dishwasher there should be a tech sheet behind the bottom toe panel....Catriver..post back.
Jan 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
50 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
