Question about Dryers
Hello, I switched out my plug to a 4 prong to fit the new outlet. Colores on dryer match up, checked it, checked fuses too. Switched cables around in outlet itselve. Still nothing can't get power to the dryer. What could it be? My Dryer is about 12 years old Wirlpool heavy duty extra large capacity. Thanks for your time
  • Dryers Master
  • 43,501 Answers
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Oct 15, 2010
I just bought a frigadaire affinity dryer. Well my plug is a standard plug. Is there any where I can find a plug to have it fight my outlet?
Dryers in the US come in 2 varieties.
A 3 prong and a 4 prong plug.
The 3 prong is older, the 4 prong newer. (The 4 has been made about 10 years)
A hardware store or an appliance store will sell both cords.
If you wish to order it online, you can buy one off of e-bay.
The cords can be switched back and forth from machine to machine.
To find out how, ask "fixya" after you buy the cord that fits your outlet. Be blessed.
Mar 15, 2013 | Dryers
Change Maytag dryer 4 prong plug to a 3 prong plug
The cover on the back should only be held on by screws and are usually easy to get off. Have you checked for these?
May 04, 2012 | Dryers
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
No heat-switched from 4 prong to 3 prong-Ground????
There should be a ground bonding ******** the Neutral (White) wire at the terminal block for 3-prong configuration. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the information, thoroughly. Instructions on how to convert from 4 to 3 prong are mentioned in the "Additional Notes" section. If you have questions, or require addtional assistance please let me know. I hope this helps you.
Jan 13, 2009 | Kenmore 67032 Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Bought used dryer. Plugs don't match. Can cord be switched?
Yes, these cords can easily be switched. When you remove the three prong cord from the terminal block in the rear of the unit, you will wire the four prong in the same way. Black and red go to the outside terminals, white to the middle terminal, and the green wire goes to the cabinet or ground screw on the outside (usually, there is a greenish looking bolt around the terminal block door area for this to go). The only difference in a 3 and 4 prong configuration is the extra ground (green) wire. Good luck and let me know if you need further information.
Feb 01, 2008 | Maytag Performa PAV3200
Open Questions:
Dryers Logo
66 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
