Question about Whirlpool LSQ8000 Top Load Washer
My husband says plastic cluprit is broken underneath the machine
    President:
  • 1,430 Answers
Plastic culprit is the motor coupler. Here is a link for properly replacing
Motor coupler video
Posted on Oct 14, 2010
MY SAMSUNG FRONT LOAD FULLY AUTOMATIC MACHINE POURS WATER FROM SOMEWHERE UNDERNEATH WHEN NOT IN USE
shut off the water first
might be a broken hose, i would want to open the back panel and check.
if it was shaking alot, it could have broken the pipe, where the water comes in, check that area.
but you would have to open the back panel in order to see.
if a broken hose then replace, if the plastic is broken at the entrance of the water then you must replace it i wouldnt try gluing it together its will just break again
good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Apr 14, 2011 | Samsung SW62ASP Top Load Washer
Diplomat ADP 8322 - 11 Flashes. Will not go beyond the Rinse cycle.
There's never a good time for the washer to stop working correctly. If a washing machine's agitator isn't working properly, your clothes won't come clean.
The back-and-forth movement of the agitator is a main function in the cleaning process of your laundry.
If your agitator isn't working, it could be the agitator itself or broken splines in the assembly beneath the agitator. Either one is a relatively easy and inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
  1. Inspect the agitator for breaks. If the agitator is broken or cracked, you'll need to replace it. A broken agitator won't operate correctly, if at all. If the agitator looks fine but isn't moving, you'll need to inspect the plastic splines in the agitator assembly located underneath the agitator.
  2. Remove the agitator from the washing machine by first removing the fabric softener dispenser cap on top of it. This cap should either pull or screw off. It it's difficult to remove, you might have to pry it off.
  3. Unscrew the bolt beneath the softener cap with a socket wrench. Once you've removed the screw, try lifting the agitator out of the washer. If it doesn't easily lift out, loop a rope underneath one side of the agitator and over a broom handle. Continue looping the rope under the other side of the agitator and back over the broom. Using caution not to hit yourself in the head, pull up on the broom until the agitator comes loose.
  4. Replace the broken agitator with a new one. Snap the new one in place and secure the bolt underneath the fabric softener cap. Place the cap back on the agitator and you're ready to start washing.
    Check the plastic splines in the assembly directly underneath the agitator, if the agitator itself isn't broken. If the plastic splines are broken or worn down, this will keep the agitator from properly moving. In fact, it might not move at all. Replace the spline assembly with a new one and reassemble the agitator by reversing your steps to remove it.
Good luck and thanks for using fixya.
Dec 24, 2010 | Dishwashers
I lost the Buttonhole fine-adjustment screw for brother ls2125
I just wanted to share my situation with you. I had the same problem. When I tried to use my Buttonhole fine-adjustment screw, it broke up and fell inside the machine. My husband opened the machine to get the broken parts out (two of them: first one - white-colored plastic broken part of the adjustment screw and a metal, half-moon shaped washer).
I called 1-877-276-8437 (BROTHER), and the person who checked the list of replacement parts said to me that this particular screw was not in the list. So that person gave me the number of the closest service center where I called.
The service person told me that it was no cost to see what was the problem, but to determine how much the solution would cost he needed to see the machine. I asked about the minimal cost of a service; it was $89+ the cost of the parts. It means the minimal cost of the repair (without the price of the replacement part) goes 14 dollars beyond the price of a new machine, which in Amazon.com today 10/2011 is $75 for the same model LS-2125(i).
My solution was to get out the broken part for which my husband unscrewed for me the front plastic shell and took out the two little broken parts. During this procedure, he realized I could use a narrow scissors to make the remaining part of the Buttonhole fine-adjustment screw turn around. This way I can still use my machine with no need of buying a new one.
Sep 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
Why does the top part of the agitator not agitate? Whirlpool Ultimate Care II
If you remove the softerner cup, the cap underneath, and unscrew the bolt you will find broken plastic DOGS. Available at all appliance parts stores.
Dec 26, 2009 | Whirlpool Washing Machines
The agitator turns freely
Remove the agitator from the machine and inspect the plastic block that is fastened to the shaft--is it cracked or the interior splines broken out? Replace the block if so. If the block looks good, the trouble is in the transmission underneath the machine or the agitator shaft is broken somewhere along it's length (you could probably pull part of the shaft out of the post).
Aug 13, 2009 | Washing Machines
Washer fills up with water, but doesn't run the wash cycle, just makes loud buzzing sound.
Will it drain?
Drain most water, take it outside pour rest out.
Roll over, check underneath see if belt broken,, or plastic guide on the cycle bar has broke off.
Jul 28, 2009 | Washing Machines
Agitator won't move
Sounds like the belt is slipping or broken.
you may be able to see it from the bottom
tilt it back.
Feb 04, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool LSQ8000 Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
