Question about Maytag PYG2300A Gas Dryer
Dryer spins, no ignition or heat. Both gas valve solenoids replaced. No igniter glow
    President:
  • 1,430 Answers
It could be several things. Radiat heat sensor, thermal fuse or safety fuse. Here is a link that should help troubleshooting the faulty part Troubleshooting a gas dryer
Posted on Oct 14, 2010
Gas dryer igniter replaced, still will not glow
You are on track that is you're issue and the solenoids should be replaced, you seem to be very able but if a video is needed I can send one. Thanks and Good Luck!!!!!!
Jul 06, 2017 | Whirlpool LGR5636L Gas Dryer
LG5791XSWO
The symptom you have indicates weak solenoid coils. The gas valve should open and the burner should ignite every time the glow bar igniter glows before it fades back off. Weak solenoid coils will usually open the gas valve until the solenoids become hot from the current and flame and then they don't have enough power to open the gas valve.
Replace both solenoid coils and your dryer will most heat and operate normally again. In order to access and replace the solenoid coils you will need to remove the front panel.
Here is the coil kit to order.
Nov 06, 2012 | Whirlpool Dryers
Kenmore Elite He3 gas dryer (110-92832100) not heating. Igniter glows red for a min or so, drum spins, hear a loud 'buzzing' noise....
The problem could be flame radiant sensor or in most cases the gas valve solenoid coils sitting on top of the gas valves. The radiant sensor must be aligned perfectly with the igniter. The radiant sensor contacts bypasses one of the gas valve solenoid coils and as the igniter heats up it makes the sensor contact trips unbypassing the coil and allowing the gas to flow and be ignited.
The problem is with the solenoid coils,
one with 2-prongs and the other has 3, if the radiant sensor is aligned with igniter and working perfectly but no gas is ignited. The buzzing sound is coming from the coils trying to operate the valves. Replacing both coils is the simple and only viable solution.
Jul 18, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer spins,screen clean,exhaust open blows good no heat
Check the coils on valve or the igniter. Access both thru Access panel on lower right of front panel. Set heated dry cycle & start, igniter should glow bright followed by a "Click" sound, which is valve opening. If it glows and no click, replace the valve coils (2 donut looking objects on top of valve). If no glow, replace igniter, usually just unplug to remove, carefully, they are ceramic and break easy.
Feb 13, 2011 | Maytag MDG2600BWW Gas Dryer
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
The igniter glows but it wont heat
The burner power circuit is good as indicated by the igniter glowing. The problem now lies in the gas valve solenoid coils failing to open the valves to allow gas to flow be ignited. The coils are located on top of the gas valves one with two terminals and the other with three. Replace both coils to make the dryer heat up again.
Aug 02, 2010 | Kenmore Dryers
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
Kenmore gas dryer is not getting hot
But the clothes drum is turning? Running? If you have a electric dryer you need to replace the heat elements. If gas you need to replace the igniter coil.
Oct 19, 2009 | Dryers
No heat
If your dryer is electric then you need new heat elements.
If you have gas you need to replace the igniter coil.
No heat
Check the following:
  1. Power. Make sure there's power going into the unit from the outlet. Check fuses or breakers of the branch circuit where the the outlet is connected.
  2. Igniter. The igniter glows bright orange when working. If it burns out, the dryer tumbles but there's no heat because the gas can't ignite. Replace the igniter and the bracket holding it. It is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube. It's about 2 inches long and mounted to the far end of the burner tube, withtwo wires attached to it.
  3. Gas valve solenoid coils. If the igniter glows bright orange then shuts off without igniting the gas, there's a defective solenoid coil om the gas valve . It is a black electrical coil mounted on the top of the gas valves. When it is energized, a clicking sound can be heard and it opens the gas valves allowing gas to flow and be ignited. If defective, the gas valves cannot open not allowing the gas to be ignited and heat up the dryer. If that is the case, replace the solenoid coils.
  4. Thermal fuse. Mounted to the exhaust duct inside the back cover panel about an inch long. It is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. Your dryer either just stops heating, or it doesn't work at all. If it is the case then replacing it is the only viable solution since it cannot be reset.
Oct 18, 2009 | LG DLG5988 Gas Dryer
Open Questions:
Maytag PYG2300A Gas Dryer Logo
339 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
