Question about Samsung SCH-u740 Cellular Phone
Clarification hi, you say to try *2767*3855# so you mean to type that in as if you were calling that sequence and press send ? plz advise as i would like to see if this is a possible solution for me, any other suggestions would be apprpeciated thanks !!
    Brigadier General:
  • 7,752 Answers
You need to type that in your phone like making a call you do not need to press send
Posted on Jun 04, 2008
When I make a call or receive one, I cannot hea what the person at the other end is saying though they can hear me. What could the problem be?
hi...
while u r on call ,when u recive a call theres option or property on ur mob,, open it check mute option make it off and try to speak ,check if they can hear ur voice, but if they didnt means ur mob speaker has problem cant send ur voice to the sender , show ur mob to repairing store ,,,
or u can tell more clarification and try to offer help...
regards ..
Jul 12, 2011 | Vacuums
Problem reloading OS on toshiba laptop
It has to configure the boot sequence into the CMOS settings. You may need to enter the CMOS settings and correct the desired loading sequence of the drive.
If I'm not mistakenly you can go to that setting by pressing the DEL button on your Laptop. There you can see the boot sequence where the first drive you want to load can changed. or you may also try pressing the ESC, first restart the laptop the press the ESC key at least twice, after the list of drive will be display select the CDROM that you want to first load.
Let me know for any clarifications.
Apr 06, 2010 | Toshiba Computers & Internet
Hi nokia n72 camera problem if click camera button means it will come unexpected error occurred. power off the device and restart is give this message please send me assistance on my e mail..
hi...dis is demon......
jus type dis code *#7307# and press call button ..it will format your cell and u ll be able to use camera.....plzzz vist
demon-qwerty.blogspot.com
Nov 13, 2009 | Nokia N72 Cellular Phone
I am not able to send emails today. I use Outlook Express and although I have not changed any settings and everything has worked in the past - today I can receive but not send?
Being able to send but cannot receive means that you cannot connect to your SMTP (simple mail transfer protocol) server. SMTP is used by Outlook in sending out emails.
Your outgoing mailserver is defined in your settings so to check if you can connect to its SMTP, you need to open a command prompt and type:
telnet you-mailserver-here 25
It should give you a new command prompt with a welcoming SMTP above. If it gave your a request connection failed, then most probably the smtp service is down.
Does your email has a Webmail interface? IF yes, try to send out your emails thru webmail temporarily until SMTP service port 25 is up. It is also advised that you inform your email administrator or service provider about this.
For further clarifications, please dont hesitate to ask me.
Sep 07, 2009 | Yahoo Mail
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
PLZ HELP!!
type in dir press enter
look for a file called setup.exe or install.exe
then type in the matching file name and press enter key on keyboard.
I am assuming you are using a floppy disk if it is coming up with A:\>
if you find folders called setup or install or driver
then you can change the directory by
typing in cd {folder name}
{folder name} is whatever the folder name is
press enter key
then type in
dir/w
press enter
these are called dos commands .
type in help and press enter and all the commands might be listed .
cd \
will take you back to a:\>
Jan 16, 2018 | ASUS P4S800 Motherboard
Forgot Nokia 1600 security code
Hi Yousaf_28,
I have a guaranted solution for ur problem. U must send me feedback and post clarification request after the solution.
I have a method to bypass ur security code. Later on u may change it.
For it, the process are :
1) When the phone asks for security code, there is unlock option in the left hand side of the screen.
2) At that time, dont enter it.
3) Instead of it, press and hold left soft key and * button at once. (dont press them alternately, otherwise it dont work)
4) If u hv properly pressed the buttons, then it will ask an option " Press * to unlock ". At that time, fastly press the * button.
5) Now u have bypassed the security code.
6) Later on u can change ur security code by same process from the security option inside the settings option.
Dont forget to send ur kind feedback and rate my solution !!! ( For posting clarification request, u have to choose clarification request instead of solution in the "post a ....." option and post it.)
Sajan (sajwhat@hotmail.com/ sajwhat_2003@yahoo.com)
May 04, 2008 | Nokia 1600 Cellular Phone
Moden
Yello,
I also tried to ping 192.168.0.1 but i got a " request time out " which means that the
-either the connection to the server 192.168.0.1 is down Or
-the server itself is down..
Thnkx
Jan 08, 2008 | NetGear DG834G Router
Samsung SCH-u740 Cellular Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
