Question about Belkin (F5D7230-4) Router (587009)
My router cant work with wireless just in computer with cable
  • painkille430 Oct 14, 2010
    is your wireless device finding the router?
    Sergeant:
  • 358 Answers
Yes because you ned first to setup wireless security
Retrieval Steps
  1. Click on the green Belkin Router Manager icon (right-click for Windows) to open the menu, or type 192.168.2.1 into a web browser.
  2. On the Belkin Router Manager menu, scroll up to Router Settings and highlight.
  3. Click to open the Belkin Router Setup page on your Web browser.
Posted on Oct 31, 2010
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
I have a belkin router but i cant find the security code for it to use it on a different computer
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Sep 05, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
How can i secure a BELKIN WIRELESS G ROUTER
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Apr 09, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cant sign in to wireless password not accepted
Try to connect your computer with an ethernet cable with the router
Open the router interface using the default gateway that your computer is receiving
Under Wireless, select security and check the security mode and check the compatibility with your operating system.
Remove all preferred wireless networks from computer
If the compatibility is appropriate, and if security key is exact(case sensitive), this is sure to work
Jan 17, 2010 | Linksys WRT54G2 Wireless Router
Ip addy changed cant connect to wireless
Turn the cable-modem (or DSL-modem) off.
Turn it on.
Turn off the router.
Turn it on.
Restart your computer.
After you do, your "wireless" connection should work.
If you have an Ethernet cable between the router and the computer,
then your "wired" connection also should work.
Jan 09, 2010 | D-Link Computers & Internet
I did a firmware update and now i cant get a wifi
After the firmware upgrade, did you configure the wireless router settings again?
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 13, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
Cant get my router to work
Connect the computer to LAN port one of the router using an Ethernet cable, access the configuration page (ie 192.168.1.254), configure the router as Dynamic IP, Configure the wireless network as (WEP or WPA), Check the IP address of the WAN section.
Note: If you have an IP address to the WAN section the Internet connection is working, Connect through the wireless network by finding the wireless network name was been created to the router.
Mar 09, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router just stopped working after my pc updated itself
You need to power cycle the router by unplugging the power for 30 seconds. If it your computer still cannot find the network, you need to change the channel of the router from 6 to channel 11 by accessing the router's setup page.
Feb 13, 2009 | Belkin (F5D7231UK4) Wireless Router
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Belkin (F5D7230-4) Router (587009) Logo
116 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
