Question about Dyson Ball DC24 Bagless Upright Vacuum
My vacuum does not have suction power through the beater bar attachment. It feels as if it is "blowing" out of the bottom of the filter basket, but no suction power.
4 Suggested Answers
SOURCE: My Dyson 07 beater bar doesn't rotate
need brakedown
Posted on May 14, 2008
  • 8 Answers
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
you need a new belt and maybe a new brushbar.
Posted on Dec 23, 2008
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
Dyson canister DC39 - beater bar won't spin once it touches the floor
Some models have the beater bar driven by the airflow from the vacuum rather than a small motor. It takes a lot of suction to turn the brush roll. Make sure there are no restrictions which will reduce the airflow and suction. Replacing the filters may help if the vacuum motor still has adequate suction.
Sep 17, 2017 | Dyson Vacuums
I have a kenmore model 116.25512506. The roller is spinning but no suction from the head. The attachments have suction but not the head. How do I remove bottom cover to check for blockage?
Is the suction control plastic ring shut?. If it's wide open you get almost no suction. See picture.
25823072-bhx41vpbxgcw2fhkwng0wody-1-0.jpg If that is closed check the long metal wand. Disconnect from the beater bar head and check the whole length of the wand and look into the beater bar head opening for something plugging it.
Aug 15, 2015 | Kenmore Vacuums
The beater bar in my vacuum does not go around and there is no suction in the power head?
Turn up side down- check if belt is intact- I would remove belt ant look for an obstruction. Not familiar with this vac but some motors have replaceable bruches on the motor. Try running and feeling for suction. The motor should sound strong when running. Remove beater brush and check for freedom of movement.
Jul 28, 2014 | Sebo Felix Classic Bagged Upright Vacuum
The suction comes on but the motor doesnt turn the beater bar nor does the red or green light come on
check to make sure power is coming from wall with a voltage meter, if not wiring issue or blown motor or wiring around beater motor
Feb 28, 2014 | Lindhaus Vacuums
Eureka 439az has no suction. Beater bar spins ok.
First thing I would check is it has a attachment hose, take off the bottom of the vacuum. Where the beater bar is and look for where the hose goes through the bottom of the vacuum, it should look like a piece of plastic pipe. Make sure that pipe is clear if it isn't the vacuum won't work. I had that problem before with a different vacuum, clear the clog and should take care of the issue. Also if you take the hose off and put your hand over the hose attachment piece you should feel suction, if you don't good indicator that line plugged up.
You can use your fingers to clear it out, if the hole hose is plugged, if you have a snake a or a cable tie, or some flexible use that to snake out the bottom part of the tube. It might make a mess so I'd do it outside or in the garage.
See if that is part of your problem, otherwise it has a canister to catch the dirt, make sure all the vents and ports are clear going into the canister .
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Sep 02, 2013 | Eureka Vacuums
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
There is suction but no rotation of beater bar
replace the drive belt.
turn the vacuum over. take the buttom plate off, you can access the roller (beater). there should be a belt attached to the roller and the motor shaft.
Apr 14, 2009 | Vacuums
No suction from base or hose attachment
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
Mar 19, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Dyson Ball DC24 Bagless Upright Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
