Question about Kenmore Dryers
Kenmore 500 dryer not tumbling, heat OK, how to fix? sheilaperret@hotmail.com
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 15, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
Nov 28, 2015 | Candy Dryers
Kenmore 70 series dryer. Heats up but quit tumbling.
belt is off or broken here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
routing of belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Good Luck Tim
May 11, 2011 | Dryers
Need a manual for replacing a Kenmore dryer drum belt
how to open the dryer:
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Mar 02, 2011 | Kenmore 500 6952 Dryer
Kenmore dryer 75731 won't tumble. It heats fine.
Hi.
The machhine is belt driven check the belt first.
If the motor is must be tested energizing it.
In all cases test the lid switch to ensure it is not opening contact when machine starts tumbling.
The wiring harness to motor must be tested.
If there is no other fault elsewhere, replace the timer board.
Start from the belt, if the machine is heating, then it is probably a broken belt.
Nov 13, 2009 | Kenmore 63942 Dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore gas/electric dryer
theordis:
When you say electrical power is working Ok ,I would assume you are saying this because the dryer is tumbling.
Which could mean you are only getting 120 volts to the unit but it will not heat with out 240 volts.
If you are getting 240 volts.
You could have an open thermostat, an open heating element. A bad timer contact or a open switch on the motor.
All these can be tested with a Volt-Ohm meter.
((((The Electrical supply must be turned off and at least one wire dissonnected from the component being tested.
woodychoppers
Aug 13, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
57 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
