Question about JRC 1500 MKII Radar
What is the value of a JRC Radar 1500 mkII new in box worth?
SOURCE: jrc 1000
Hi , I have a JRC 1000 with manual if it can helps ( in English and french but i ma in france. You can also use the installation manual of JRC 1500 available on internet under pdf format , very similar ( same screen and operating interface )
pcg1@orange.fr
Posted on Sep 07, 2008
greenspan
  • 1734 Answers
SOURCE: i need schematics off jrc radar 1500
Ask at http://manualfox.com/schematic.htm
If anybody can find it, this is the right place to ask.
Posted on Jul 31, 2009
  • 111 Answers
SOURCE: JRC 1000 MKII bearing pulse error on receiver
Normally the bearing pulse comes from the bearing pulse generator built inside the motor. Every time the motor turns it sends a pulse down the line showing the radar that it is indeed spinning. There is also a Heading pulse that comes from an electric eye elsewhere in the housing. The other thing could be that the wire carrying the bearing pulse is not getting back to the display. More so than often, it's the motor. I would have the display sent out to be checked on a simulator if there is a marine electronicshop nearby.
Posted on Oct 30, 2009
TechnoMarine
  • 132 Answers
SOURCE: seeking replacement magnetron for Raymarine M92652 4kw radar
give ne an email and i will quote it
Posted on Jan 17, 2010
  • 35 Answers
SOURCE: JRC Radar Scanner when rotating
There is a seal on the antenna scanner shaft, just below the seal there are two bearings, thou the antenna are enclossed moisture still get inside and get to these bearings. Try and get a small amount of wd40 on the bearings, if not, you will soon begin to see false echoes on the screen because the motor on the scanner or antenna will begin to work harder causing a drag causing these echoes. Good luck.
Posted on Jan 30, 2011
Need to know how to connect the 12 v dc power to the unit as I lost my power cable for radar 1000
As you look at the back of the display unit, the power plug has 7 connection posts.
Top left is pin 1 Bottom Right is pin 7
Pin 1 ..... + 12v
Pin 2 ..... - 12v
Pin 7 ..... Boat Ground
Rob
Oct 14, 2010 | JRC 1000 MKII Radar GPS Receiver
JRC 1000 MKII bearing pulse error on receiver screen. Connections to scanner good and scanner turning. How can I determine if the problem is in the receiver? How can I fix it? louonboard
Oct 27, 2009 | JRC 1000 MKII Radar GPS Receiver
Hello, I need a power cable for my JRC 1000. How
Hello there,
I also need this very same power cable. Did you find one already? maybe you can tell me wich one of the 7 input connections is the + and - DC power connection so I can connect this thing myself with a home made power cable. Greetings. Stan (holland)
stanvanroermund@hotmail.com
Thanks!
Oct 03, 2009 | JRC 1000 MKII Radar GPS Receiver
Error BZ
This is a bearing pulse error. Either the bearing pulse generator inside the motor is bad (Replace the motor) or it's in the radar cable or display.
Jun 15, 2009 | JRC 1000 MKII Radar GPS Receiver
I need schematics off jrc radar 1500
Apr 27, 2009 | JRC 1500 MKII Radar
Draw down is to high
found my fault not i the power cable in, but the interconnect to radar dome..approx 50mm from radar screen a break in the wire, found it just by wiggling the cable.. the set wont power up if the interconnect not connected or is faulty
Apr 07, 2009 | JRC 1000 MKII Radar GPS Receiver
Jrc 1000
pcg1@orange.fr
Jun 13, 2008 | GPS
Raymarine 41xx - Message "bearing pulse error"
More than likely your motor is going bad. Inside the motor is your bearing pulse generator. Replace the motor and you should be ok.
Apr 28, 2008 | JRC 1500 MKII Radar
GPS Logo
Top JRC GPS Experts
Shehu Pro
Shehu Pro
Are you a JRC GPS Expert? Answer questions, earn points and help others
