Question about GE JVM1441 Microwave Oven
Oven Light wont turn off. Contact relays on smart board likely not working. Solution, Please?
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Light wont turn off on GE profile
WHEN THE BULB BLEW IT PROBABLY BURNT OUT VIOLENTLY AND DAMAGED THE RELAY ON THE MAIN BOARD THAT CONTROLS IT. WILL PROBABLY HAVE TO REPLACE THE MAIN POWER BOARD WHERE THE RELAY FOR THE LAMP IS LOCATED
Mar 04, 2018 | GE JVM1790 Convection / Microwave Oven
I have model # JVM1430WD002. Both the under light & ventilation fan are not working. When I press the button, I can hear a click but nothing comes on.
Sounds to me like you main control board is failing. The relays on the board that control the light and fan are closing but the points in the relay are probably burnt and not making contact. You will probably need to replace the main control board. Hope that helps.
Aug 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JVM-1650-ch01 space saver oven hood and the oven light will not turn on. I've replaced the bulbs and the read out says that the light is on but the loght will not turn on by pressing the...
Sorry to read about your problem, I hope this helps you out.
The main control board controls the lite with a relay,, the relay is defective or you may have a broken wire
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
New smart board installed in microwave, still doesn't work
It sounds like he "shotgunned" and blamed the board without experience enough to know the difference or to test it.
We would need to know what exact problem you're having and what your full model number is.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 25, 2010 | GE Microwave Ovens
Microwave PLMVZ169 GCB night light push button does not work. Replace the light bulb. Push button still does not work. The work light does when I push the night light it stays on. Just wondering how to...
Q - While trying to change the light bulb on the oven, the bulb broke. When it did, it threw the circuit breaker and the whole oven went out. After resetting the breaker, everything on the oven works except there is no power to either light socket. Any ideas or suggestions on what to replace?
A - You tried to change the light bulbs with the power still on.....tsk tsk!!
Hate to say this....but probably blew out part of the circuit on the smart board ( the brains behind the key panel you touch ) when the short blew. The light relay on the smart board may have been damaged but 9 out of 10 times when I check them, the board itself is damaged.
check out this problem.
please do rate the solution.thank you for using fixya.keep updated.thanks,
May 03, 2009 | Microwave Ovens
Advantium 120 fan and tray keep running
Looking at the service manual here, I'd bet that relay number RY6 is shorted on the "sub PC" relay circuit board, or its driver transistor on the main "smart" board is shorted.
Unless your technician does component-level repair, he'll probably want to just sell you a new sub board, or main ("smart") board, or both.
They list for $64.78 and $109.83 respectively here. Hard to tell what they'll mark them up to.
Then add about $150-200 for the labor.
On the other hand, we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
Or you can tell your technician about our services.
William E. Miller
[email protected]
Jan 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Sanyo EM S667W 1000W 240V Microwave.
Please do not operate the microwave (other than short bursts when testing) until the cooling fan is working again.
Otherwise, the magnetron will be destroyed, and that's expensive.
When the magnetron overheats (since the cooling fan is not working) the magnetron thermostat opens up to kill power and protect the magnetron until it cools back down again.
Chances are you have a bad connection, bad relay, or bad component driving the relay on the control circuit board.
If you will scan (at 300dpi if possible) the schematic, and e-mail it to me, along with clear digital photos of both sides of the board, I can probably help you get this fixed.
Feel free to contact me directly (and please remind me of your full model number).
William E. Miller
[email protected]
Dec 12, 2008 | Sanyo EM-W3000W 1000 Watts Microwave Oven
GE JVM1441 Microwave Oven Logo
59 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
