Question about Dometic RM2620 Refrigerator
DM2662 Refrig, stopped working.checked fuse, reset connectors. tried to start gas. i hear it click but doesn't start. what could be wrong. it should be ok, it's only 6 years old. i'm having trouble getting a service person to come. i understand that i have to take doors off to get it out of the rv. i'm hoping it's a quick fix. suggestions?
  • hgeving Oct 14, 2010
    is it possible to get a repair manual with diagrams which show proper routing and connections? I'm kinda handy with tools. should be able to do it. can i try the thermostat out somehow before i tear the refrig out of the wall?
  • Dometic Master
  • 6,674 Answers
Can you reply with verification on whether it's an DM2662, or DM 2620, or with whatever model it actually is, just so we get this right. Does it work on hydro/ AC mode?
Posted on Oct 15, 2010
  • 22,156 Answers
By the sound of it i think it just needs a new thermostat ,a universal one will do it but fitting the thermostat isnt a problem its running the sensor pipe thing thats the hard part ,taking the cabinet apart to fit it correctly as original ,what i do if customer doesnt mind is to run it on the outside of the interior till i get to the ice box then tuck it in somehow ,sorry thats about the best i can offer
Posted on Oct 14, 2010
2000 kia sephia cranks but engine wont run
The fuel pump may have died. Can you hear it turn on briefly, by turning the key to "on"? You may have to stand by the gas tank while someone turns the key to on. It should turn on for about 2 seconds and then stop, after pressurizing the fuel system. If you don't hear it, then check the fuel pump fuse. If the fuse is good, and the pump won't run, one needs to check that the fuel pump wire at the tank connector has battery voltage on it when the engine is cranking-then, you can assume the pump needs replacing.
If the pump is working and you have gas up to the engine, you would next check the ignition system. Start that by checking for spark on one of the spark plug wires.
Apr 21, 2013 | 2000 Kia Sephia
I got a 88 gmc jimmy 2.8L just replaced the starter and now it wont start. bthe fuel pump wont turn on and the ecmb fuse is still good. where else should i check for a problem before replacing the fuel...
if you have someone try to start the car while you hit the gas tank in the centre of the fuel tank and it starts then the fuel pump is no good.note this doesn`t always work due to how bad the pump is seized.if you look for the fuel pump feed wire under the hood,its a green wire with a black plastic connector and with some one again trying to start the car and with a test light connected to the connector it should light up.if it does then the pump is no good.another way is to have someone listen at the fuel tank and feed power to this same wire if the pump is working then they should hear the pump run,they may have to listen at the filler neck with the gas cap off to see if they can hear it run.
Sep 16, 2011 | GMC Jimmy Cars & Trucks
Gas Is On, Press Ignitor and charcoal doesn't ignite
Make sure the ignitor is sparking. sometimes they fail or spark in the wrong place. If no gas is flowing, try shutting off the tank and waiting about 15 seconds, then open the tank back up. Some models have a flow restrictor that shuts off the gas, you will hear a slight ping or click as this resets.
Jul 10, 2011 | Weber Performer Grill
Our GE refrig PSI23MGPB BB stopped working. We unplugged it and it started working for one week...we repeated the process and it remained running. What can we do to prevent this from happening again? We...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and refrig not functioning. Is there a
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Hello I own a profile refrig. and the ice maker stop working three days ago. Since then food is not getting cold on the freezer side and refrig. side. Could it be a thermostat?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 31, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My 1994 Volkswagen Jetta won?t turn over. It sat for the winter in Canada, and I tried to start it last weekend. Initially it turned over but didn?t start (most likely due to the fact that I only had...
if you keept trying to start it with no luck it could be possible you have flooded the cylinder. get a can of starter fluid and spray it in your intake(air filter box) and try to turn it over. if it trys to start you should drain all fule. add new fule with a can of octain boost. if car does not start pull spark plugs and try to drain cylinder
Feb 22, 2010 | 1999 Volkswagen Jetta
Freezer and refrig not cooling
it might be a cooling gas problem
you first check it by caling l service men
also please give me ratings on this........
Aug 25, 2009 | Whirlpool ED2FHEXN Side by Side...
When upluged from 110 volt the refrig does not automatically go to gas and work
I checked the 12 volt connection and cleaned the electrical connectors. When I restarted the refri for gas I could then hear the ignitor working - I tapped the gas valve a few times and heard the gas ignite. I believe it was corroded connectors and an air bubble in the gas line.
thanks, Ron
Apr 01, 2009 | Refrigerators
Dometic RM2620 Refrigerator Logo
87 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
