Question about Pegasus Technologies Home
Our Pegasus bathroom drain stopper broke and we now have no way to plug the drain.
4 Suggested Answers
  • 2976 Answers
SOURCE: etching on Pegasus sinks from standing water on clear sink
You can get an acrylic sealant to put around the drain. It will fill the void where the flange on the drain hole and the sink meet. Possibly an epoxy would work but some tend to yellow with age.
Posted on Jul 24, 2009
  • 128 Answers
SOURCE: stopper came out Pegasus bathroom sink
Pegasus make several models but I'll make an assumption that it has a pop-up plug actuated by a rod just behind the tap head.
If correct....
Under the sink in the cabinet you will see the rod comes down and connects to an adjustment fitting and into the main drain line from the sink. There will be a fitting on the drain line holding the connection. Inside is a metal ball and connecting rod that links to your plug.
Remove the fitting.
Slide the ball and rod partially out.
Put your plug back in.
Engage the rod again (you will need to fiddle a bit here).
Tighten the fitting.
Run water to ensure the fitting is tight and not leaking.
Should be good to go.
Please rate this answer if it gives you some direction.
Posted on Mar 13, 2010
  • 122 Answers
SOURCE: The bathroom drain stopper will not stay closed.
there is a small compression nut on the drain, it needs to be tightened slightly. look under the sink when you pull the lever up close the stopper, you will see where it connects to the drain. tighten that nut slightly.
do not over tighten or you won't be able to move the stopper at all, you just need enough pressure to hold the weight of the lifting rod and stopper in place.
Posted on Aug 15, 2010
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
I have a glass bowl sink in my bathroom. The pop-up drain is stuck in the down position and will not release. How do I fix it??
You'll need to access back side of sink bowl and locate drain mechanism, most likely either the plunger rod has loosened up from clevis rod or clevis rod is positioned to far in towards drain line causing it to bind. Check diagram for assistance in locating parts.
Is the plunger rod tight or loose? You can also loosen clevis screw and see if the plunger rod will slide freely. If it does try moving the horizontal pivot rod up and down, while doing this you should she your drain plunger moving up and down. If it does not then most likely will need to replace plunger mechanism by removing the retaining nut on the back side of the drain line. This will allow you to disassemble the actual drain plunger but I would definitely start with the mechanism of the stopper and clevis where it attaches to horizontal rod.
Sounds like a simple binding. Always be sure there isn't anything stored under your sink which could be causing the problem. Sometimes the most obvious is the last thing we look at.
Good luck.
Aug 16, 2013 | Pegasus Technologies Pegasus Clear Round...
Hi I recently bought a CA84667CBN bathroom faucet but lost the manual. How do I connect the water stopper?
http://www.hometips.com/diy-how-to/bathroom-faucet-installation.html
These pictures are not very good and there are videos because it's kind of hard to explain but, I'll try. The drain stop rod that goes through the fixture and would hang in your vanity should have a piece that bolts to it with holes in it. you need to pick the hole to go over the shaft taht sticks out of the drain pipe, That controls the stopper, taht will close the stopper when pulled up and, will open stopper enough to let water drain. You use the "v" shaped piece with the 2 holes in it to attach the two together. You have to position the v piece over both sides of the plunger piece and then squeeze and put the whole thing over the shaft of the pluger actuator. If you type, "how to install a faucett" in your search window, you can pick a video on how to install a "bathroom faucett" that will give you pictures. It's really hard to try to explain.
Jun 12, 2011 | Moen Home
I am trying to use a plunger in a slow drain. bathroom lav. The pop-up valve stopper is in the way of my plunger. the Pop-up valve is a Price- Pfister. My past experience with other older pop-up valves has...
Some of the drain plugs have holes or slots in them so that the stopper can not be removed without taking the actulating lever out from under the sink. This rod is part of the linkage that is hooked to lift rod on top, Unscrew retaining nut to remove rod so you can take stopper out. Remember that any water that is in sink is going to run out of this hole once you remove rod. Good luck and thank you.
Feb 21, 2011 | Price Pfister 47 Series, Lavatory Drain...
We have american standard bathroom faucets with speed connect drains and they're draining slow
Disconnect the speed drain and pull the stopper out to see if it drains fine with the stopper out and if it does then you need to clean the parts and reinstall same.
Feb 11, 2011 | American Standard Hamilton 4 In. Centerset...
Hi I have a KOHLER Fairfax Chrome Double-Handle WaterSense® Bathroom Faucet and the drain stopper keeps popping out. My husband and I have tried numerous times to fix it and can't. I also cannot...
Un screw the nut on the drain tail piece that attaches the rod to drain pipe .Pull the rod out just slightly.Hold the drain plug in the hole with the notch sitting side ways.Push the rod back in angled so that the tip inside drain is angled up.You should feel it go through the notch on the drain plug .If it has you should not be able to pull it out.Tighten the nut hand tight and work the plunger it should be attached .If not loosen the nut again pull back on the rod and shift it around until you feel it go through the notched hole on the plug bottom
Jun 22, 2010 | Home
May 12, 2010 | Home
I AM LOOKING FOR A THE RING AROUNG THE DRAIN HOLE FOR A PEGASUS BIMINI VANITY
Standard rings can be bought at your local hardware store. It will be easiest to replace the whole stopper assembly instead of trying to match the ring to an existing stopper. You will need some plumbers putty and a pipe wrench.
Feb 11, 2010 | Pegasus Technologies Pegasus Pegasus...
Stopper came out Pegasus bathroom sink
If correct....
Remove the fitting.
Dec 22, 2009 | Pegasus Technologies Home
Etching on Pegasus sinks from standing water on clear sink
Mar 16, 2009 | Home
Home Logo
831 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
