Question about Kenwood KDC-5019 CD Player
No display and controls dont respond...It does light up and flip
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Oct 02, 2012 | Dishwashers
My nokia 6085 mini display dont lights but it shows time in reversed position
your device has problem of flat cable, see on you tube how to change flat cable of your device or search on Google (service manual level 3), if you are not able to change, give some oficial repairer.
Jun 28, 2012 | Nokia 6085 Cellular Phone
Flip the screen
Flipping the screen is part of the Display in the Control Panel. You have to go to the Settings tab then click Advanced and look for Rotation.
Click Start/Control Panel or Start/Settings/Control Panel then look for Display or Appearance and Personalization. Open the Display then click Settings/Advanced/Rotation.
Jun 08, 2012 | Computers & Internet
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
My NewBrand FLIP MINO HD2 once switched on and after having pushed red button ( recording ) is now blocked ! No responding to any command or doing any action ( no recording, no display, red light rechargin...
return it for a refund! i bought one, it did the same as yours. i returned it and bought the 2nd one. It did the same as the first one (and the same as yours.)
It is a piece of junk. Supposedly the previous Flips were good, unfortunately, I didn't have the previous models so my experiences only are bad.
May 08, 2010 | Pure Digital Flip Mino Digital Camera
After a power blackout in our neighborhood the oven display showed a blinking clock time-still keeps time- which could not be reset. The soft panel does not respond to any setting to turn on the oven in...
Try turning the breaker to that unit off and keep it off for 20 minutes or overnight, if possible, then flip the breaker back on. If it still shows the PF code, call us and we can get the correct part to you. Hope this helps.
Aug 28, 2009 | GE JTP20 Electric Single Oven
No power, even though it is plugged in. The breaker box had no flipped fuses.
they can trip inside you can't see it so flip them on ...off fast and hard push off very hard to reset
Aug 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Blackberry Pearl 8220 backlight slow to respond
That sounds really annoying. If its not a hardware issue maybe you could look at the screenlight app to force the light on.
http://appworld.blackberry.com/webstore/content/6808
Jun 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
ULine 2175RF Digital Touch Controller not responding.
Hi
You will need to remove the grill. Unplug the unit, Then on the control board you will see 4 wire with a black connector. Unplug that and plug it in 4 or 5 times. Make sure you dont bend the pins. Then plug the connector back in and plug unit back in. You should have better response on the display. They have a special coating and the pins needs to be cleaned this way.
Jan 18, 2009 | U-Line Refrigerator Ice Maker
Kenwood KDC-5019 CD Player Logo
23 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
