Question about Kalimar V-20S VIDEO TRIPOD
Upper post crank
The crank handle that raises and lowers the uper post has broken. Is this par tavailable anywhere?
  • 310 Answers
I find these parts at second hand stores.
Posted on Jul 02, 2008
On a 2000 explorer 4.0 Soho do I have to remove the injectors to remove the lower intake
? 12:22
Jun 11, 2013 - Uploaded by Sum Guy
REMOVE UPER INTAKE 97 EXPLORER V6 4.0 ... I was told that all I have to do is remove the fan belt to get access to it ... FordExplorer 2000 intake manifold gasket upper lower P0174 by froggy - Duration: 36:54. by froggy 36,588 views ... Ford Explorer 4.0L SOHC Rough Idle P0171 P0174 Lean Codes ...
Putting the lower intake on my 1997 Ford Explorer 4.0 OHV ...
? 5:23
Jun 27, 2010 - Uploaded by origionaldz
Putting the lower intake on my 1997 Ford Explorer 4.0 OHV sport .... I do have a 2000 5.0 ... @michaelheiland123654 To dothis job, you have to remove the alternator, unbolt the AC compressor, remove upper intake manifold, remove fuel rail,remove all injectors, ... Do you have the SOHC or OHV version?
1999 Ford Explorer 4.0L -need assistance on removing upper intake ... > ... > Ford > Explorer ' Explorer Sport Trac
Sep 20, 2011 - 1999 Ford Explorer 4.0L -need assistance on removing upper intake ...Are you sure you have the OHV/pushrod engine and not the SOHC engine? ... Do youhave the upper intake manifold loose, you just are unable to ... the lower intake gasket, valve cover gaskets, Injector o-rings, plugs and wires. Thanks ...
How to replace upper intake manifold gaskets - Ford Explorer
Dec 09, 2015 | Cars & Trucks
The upper part of freezer is warm and the lower part is cold. what gives?
sounds like a defrost problem.. but be sure the freezer fan is running.. if the fan is running I would look at it being a defrost issue.... I hope this helped........ ken
Sep 29, 2014 | Refrigerators
Motomaster motorcycle jack won't raise
Hi Bogdan:
Seems there may be some confusing instructions.
Here's what I would try. My approach would be intended to get the bike off the stand before I tried to trouble shoot the motomaster jack.
1) Use the handle to rotate the release valve to the right (clockwise) until it is snug.
2) Pump the jack to try to raise it. If it raises, then press the release pedal and use the jack handle to slowly rotate the release valve to the left (counter-clockwise) to lower the deck.
3) If it does not raise, I would use a separate jack to raise it, then follow the prescribed lowering procedure, and at the same time, use the control on the extra jack to manage the lowering.
Once you get it partially lowered, hopefully the motomaster jack will start to function and you can lift the bike far enough to remove your extra jack.
Hope this helps.
To let me know if it works for you, please reply as a comment to this post..
Jul 29, 2013 | Motormaster Cv Joint Front Female*-ATV
How do i change upper and lower ball joints on 2000 ford ranger
They need to be pressed out then back in. Take it to a shop and save yourself a lot of headache
Feb 23, 2010 | 2000 Ford Ranger SuperCab
How do you replace or repair the chain drive on a Dewalt DW735 planer? I went to use my planer and the height adjustment was very tight. I tried to raise it and lower it and even lubricated the 4...
hi i have a coleman powermate 18 volt cordless drill
i put the batt in the charger for a long period of time
and still not up to par
i wonder is it the batt or the charger??
Nov 28, 2009 | Dewalt Tools & Hardware - Others
The blade will no longer raise or lower on my Jet
Make sure the set screws in the handle and gear are clamping against the shaft..
Jun 17, 2009 | Jet Saws
Broken cable in older Coleman pop-up to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Lowering/raising the spare tire
there should be a crank handle under the hood and an access hole just above rear bumper
Jun 28, 2008 | 1999 Mercury Mountaineer
Kalimar 3CLB Crank Broken
I have the 3CLB and it is missing the quick release plate. It is in very good condition. Am willing to sell the whole unit.
Jun 18, 2008 | Photography
Photography Logo
206 people viewed this question
Top Kalimar Photography Experts
JP Services
JP Services
Tony Parsons
Tony Parsons
Are you a Kalimar Photography Expert? Answer questions, earn points and help others
