Question about Epson Stylus CX6000 All-In-One InkJet Printer
Epson stylus dx6000 error message e-02 have tried
Epson stylus dx6000 error message e-02 have tried putting new cartridges in and still wont recognise them or let me clean the print head
  • Anonymous Mar 21, 2014
    I have replaced all the cartridges
    Genius:
  • 1,447 Answers
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Posted on Oct 14, 2010
Testimonial: "Thanks, thats wot i thought. cheers"
How do i change cartridge on cx5900
Please go to the following manual link http://www.manualslib.com/manual/48206/Epson-Stylus-Dx6000.html?page=21 for understanding how you can you change the cartridge. Hope it will work.
If you still not able to change the Epson cartridge, please follow us
Oct 14, 2014 | Epson Office Equipment & Supplies
I have not been able to activate my dx6000 epson scanner option. The printer works great!
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX6000-All-in-One-printer/Drivers-Support?target=article&extn=.html&articleId=1344
Try this link. It might help.
Feb 05, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Message on Epsom Stylus DX6000 reads E-02. How to fix?
E-02 is an ink cartridge error, possible causes incude faulty ink cartridge chip, incorrectly installed cartridge, dirty contacts, ribbon cable not fitted correctly to carriage or faulty CSIC board in the carriage.
Your first step would be to remove all of the cartridges and clean the contacts and cartridge chips with contact cleaner or alcohol wipes. Refit cartridges ensuring that they all click into place and check the ribbon cable into the carriage is secure.
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Changing ink in Epson DX6000 printer
Normally, you lift the scanner/copy bed up while the unit is on and then the cartridge moves to the center.
Have you tried this and if so without success? let me know so I can find the secret if there is one for you.
Regards,
Worldvet
Jan 28, 2009 | Epson Stylus DX4200 All-In-One InkJet...
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus DX6000
E-90 error is an indication of an internal problem on the printer itself. The only thing that you can check/do is to power cycle( turn it off and unplug from power supply) the printer and check for obstruction inside and press on the cartridge cover on the right hand side of the printer but do not manually move printhead to position where you can take the cartridges out it will damage the printhead. then replug and turn it back on. if you get the same error, check for date of purchase if its still within warranty call epson for replacement and a set of ink will be included with it. Hope that helps.
Nov 10, 2007 | Epson Stylus DX4200 All-In-One InkJet...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
2,202 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
