Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My adjatater is lose how do I tighten it? - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
    President:
  • 1,430 Answers
Try this link it should help
Washer agitator video
Posted on Oct 14, 2010
My 2015 Harley Davidson radio keep cutting on and off while riding
might just be a lose connection, can happen a lot on the Harley radio with the road bumps. you would need to tighten down the cable into the radio might have to tighten the spade connectors as they can open and come lose.
Jun 30, 2017 | Harley Davidson Motorcycles
New Rancher 455. Ran for a few minutes then tried to tighten chain but adjuster was maxed out (completely tight clockwise). Removed cover, now can't get tension adjusting pin in hole in bar....pin sits...
Ok.. with the cover off the clutch you notice the screw and the pin that is suppose to go into the hole.. with the chain on the bar back the screw until the pin sits in the hole of the bar.. The chain should be lose you will see the chain dangle at the bottom of the bar.. put the cover back on with it lose.. hand tighten the two nuts that hold the cover on. with the bar in hand and you pulling the bar up make sure the two nuts are on tight enough so the bar does not move but dont over tighten it. tighten the screw you will notice the chain starting to move, and start to tighten up.. once the chain is in the grove of the bar grab the chain and move the chain with your hand to make sure you have not over tighten it. if the chain moves freely and is not lose ( you can also double check how tight it is by grabbing the chain below the bar and letting it go if it snaps back into the bar and doesnt hang there you are where you need to be.) tighten the two nuts up on the cover and start up the saw. Run the saw to make sure everything is all set and nothing is lose before cutting.. If the chain never get to tighten up you need a new chain. buy a new chain and follow the steps again. let me know if you have any questions
Jun 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My ge washer does not wash, it just spins. Help me fix pls.
if you mean it does not adjatate that would be your adjatater coupler grab adjatater at bottom both sides pull adjatater up it will be hard but it will come. when that comes of you will see adjatater coupler remove bolt in center of it that part will pull up. now to replace that part ge changed it about 2 years ago when you get the new coupler you will need the new bolt. 'GE sells that coupler as a kit comes with the new bolt thats the way to go...if I helped you please vote if you need more help please ask good luck
Feb 08, 2011 | Washing Machines
Lose pully
Remove the pulley from the shaft (the large drum pulley?) and inspect the center. If it has been 'egged-out', you need to replace the pulley and the belt together. Make sure to tighten the set screw firmly when replacing the parts. Hope this helps!
Mar 29, 2010 | Frigidaire FEX831CS Top Load Stacked...
How i clean fabric dispenser area like under
You can buy super clean from Wal art or a parts stotre it cleans very good buy a spray bottle and use a green scratch pad to clean with and wear gloves as it is hard on your skin afer cleaning it then wipe away dirt with paper towels so as not to damage any plastic parts, I use this stuff on everything it gets rid of greese and any kind of hard grim spray it on let set fow few minutes and then clean it up.
Jul 26, 2009 | Whirlpool GSC9455 Top Load Washer
How to tighten e90
here is a take apart instructions, the only way is to see if something is loose or broken inside.
http://www.formymobile.co.uk/e90disassembly.php
Jun 05, 2009 | Nokia E90 Smartphone
Kitchenaid washer top load will not adjatate or spin
Bad/broken coupler connects the motor to the gearcase.
Mar 07, 2009 | KitchenAid KAWS850LE Top Load Washer
Kenmore 110.92282100 won't adjatate with aload.
Does it spin? Or just an agitation issue. Sounds to me like you need a new clutch. The clutch is #5 and costs about 40.00.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
