Question about HP Pavilion F1703 17" LCD Monitor
Hp 1703 monitor resoldered the coils in the back still having same problem with monitor going blank after a few seconds. now see a faitnt outline of page am i still having the same problem or is it the backlight
  • 11,361 Answers
Did you check all four transistors (c5706/5707) on the board, also look at the bottom rubber seals of the purple casing electrolytic caps to see if they are bulging. And yes, yo can have bad lamp assemlies problem due to age or poor solder connection at the ends of the lamps.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 14, 2010
  • Bud Martin
    Bud Martin Oct 14, 2010
    Oh by the way, did you remove the old solder, clean the inductor leads and then resolder them back on and Ohm them out?
Problems with my monitor
See HP 1703 album. You need to remove the old solder from the 4 inductors, clean the inductor leads and resolder, also look for purple caps with bulging tops, replace them.
Jun 23, 2010 | HP Pavilion F1703 17" LCD Monitor
My hp pavilion F1703 monitor goes blank about every 30 seconds.
Thsi model has known problem with bad solder joints due to contamination, you need to remove the old solder on the four inductor leads, clean the leads eal well and resolder, see my pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Al so look to see any one of the capacitors have bulging top, they should be completely flat top.
Jun 06, 2010 | CTX S762A 17" LCD Monitor
I have a HP 1703 monitor and it doesn't work with my Dell tower
Below is link to a page that has downloads, troubleshooting and manuals for the HP 1703 monitor.
http://h10025.www1.hp.com/ewfrf/wc/product?product=324213&lc=en&cc=us&dlc=en&lang=en&cc=us
I hope that you find this information helpful. You man need to install a HP 1703 driver on your computer for it to work.
If you do find this helpful, please leave positive feedback for me.
Thank You,
Brian
Jan 25, 2010 | Computers & Internet
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Picture ok for a few minutes then go blank
it is your monitor inside problem, you need to know follow issue:
1) inverter board some where the component got less connection
like MOSFET drive or capacitor swelling need to resoldering or change.
2) the back light lamps worn that most cause this symptom, need check or adjust inverter driver to match them work well
3) DC power supply filter capacitor swelling should be this problem, check and fix it.
hope help you something do well, please feedback any question any time,
pleaae take a rating let me know how much helped you thanks!
May 27, 2009 | Dell E176FP 17" LCD Monitor
Whilst using my computer the monitor went blank. I turned the monitor off and back on. It stayed on for less than a second before going blank again. There was power to the monitor. I left it for a few...
can u boot into the safe mode and see if the monitor will work cause it sounds like to me that you either have a driver that is failing or the monitor is failing
Aug 18, 2008 | HP Computers & Internet
Blackout problem
Normal problem is dry solder of Inverter transformer and/or transistors around it .
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
Mar 28, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Aug 15, 2007 | AOC LM729 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
90 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
