Question about PIONEERPOS Computers & Internet
I HAVE A PIONEERPOS MODEL MAGNUS TOUCH SERIAL NUMBER 740 1742, 4 DAYS AGO ONE OF MY WORKERS TURNED OF THE COMPUTER, AND ON THE NEXT DAY I TRIED TO BOOT IT UP AND THE SMALL GREEN LIGHT WOULD FLASH ON AND OFF BUT THE SCRREN WOULD NOT LIGHT UP, AND WE HAVE TRIED EVERYTHING THAT WE CAN THINK OF AND IT WILL NOT COME ON. DOES ANYONE THERE HAVE AN IDEA WHAT THE PROBLEM IS?
premtech
  • 934 Answers
SOURCE: won't turn on
What you have there is a V27 Chassis manufatured in 1999..
But it is the same chassis that was later used in their WS55517 65517 and 73517... Regardless of the outcome here are some common caps that ALWAYS need to be replace:
C979 2.2uf 200v
C531 2.2uf 160v
C551 2.2uf 160v
C981 22uf 50v
C402 47uf 35v
Now to your problem, it could be a number of things. The regulator could be suspect, (Ic951 which is a STRF6628) but you might try the following before taking any gunshot approaches. This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Hope this helps!
Bill
Posted on Nov 16, 2007
s4u311
  • 813 Answers
SOURCE: hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Posted on Jul 16, 2008
  • 4 Answers
SOURCE: My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Posted on Mar 25, 2009
  • 7 Answers
SOURCE: Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
Posted on Jun 24, 2009
SOURCE: On my Zenith Plasma model #Z42PX2D, when we turn
This is a common problem on these plasma TV's. The problem resides inthe high voltage boards known as the X and Y Sustain boards.. You canpurchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Posted on Oct 16, 2009
Fault code f05 whirlpool microwave
Magnus, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Magnus), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Sep 30, 2012 | Whirlpool Washing Machines
Cannot boot up windows xp or do system recovery
It's easy Megan, just chill, lol!
Look at the back of the computer next to the Windows product key, or up on the side of the computer tower, for the white Service Tag.
In the tag write down what it states next to S/N.
This is the Serial Number.
(DO NOT post on here. Only give to an authorized HP representative)
Now contact HP Support, and ask for the Restoration Disk.
(HP bought out Compaq a long time ago)
In the USA the disk is free. The shipping and handling is not.
$17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
In the US call 1-800-474-6836
24 hours a day, 7 days a week.
http://www8.hp.com/us/en/contact-hp/phone-assist.html#section1
Outside the US use HP Support Worldwide,
http://www8.hp.com/us/en/contact-hp/ww-contact-us.html
When you get the disk, turn your computer on, and put the disk in the optical drive's tray. (CD/DVD drive)
When asked choose Repair. (Non-Destructive Installation)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 03, 2012 | Compaq Computers & Internet
A6512p recovery disk
Really?
HP Support has them for F_R_E_E
The shipping and handling is not free.
In the USA, for a 5 to 7 day ship it's $17
For a 2 to 3 day ship it's $24.
Call 1-800-474-6836
Have the Serial Number written down to give to the nice representative.
It's in the white Service Tag on the back of the computer tower, next to the Windows product key; or up on the side of the computer tower.
S/N = Serial Number
{DO NOT post a serial number on a public forum. Only give to an authorized HP representative }
Outside the USA use HP Worldwide Support,
http://www8.hp.com/us/en/hp-information/summary/ww-contact-us.html
Regards,
joecoolvette
Jul 21, 2012 | HP Pavilion a6512p-b PC Bundle PC Desktop
How to unlock computer
BIOS locked? CMOS or BIOS password?
Remove power. Open computer case.
FOLLOW Anti-Static Precautions!
Remove coin-cell CMOS battery.
Press the Power On button in. Hold in for a count of 10 seconds. Let go.
Repeat 2 more times.
(Drains residual power)
Reinstall CMOS battery.
Connect to power. WAIT 1 minute, turn the computer on.
Also the motherboard may have a jumper on it, which you move in a CORRECT procedure, to remove CMOS settings. (Such as a BIOS password)
Windows password set by the owner/administrator?
Use the Restoration Disk (CD) and perform a Full Install.
(Destructive Installation)
Wipes off all of their data, and gives you a computer as it was, day 1 from the factory.
Don't have the Restoration Disk?
Contact HP Support.
In the USA the disk is free. The shipping and handling are not.
Toll-free phone number in US is, 1-800-474-6836
Have your Serial Number written down, to give to the nice representative.
It is in the white Service Tag, on the back of the computer tower, (Next to the Windows product key), or up on the side.
S/N = Serial Number
(NEVER give out on a public forum. Only to authorized agents of HP )
For countries other than the US,
http://welcome.hp.com/country/w1/en/support.html
Now,...what Product Number is it? (P/N in white Service Tag)
Post back in a Comment.
Regards,
joecoolvette
Apr 16, 2012 | HP Computers & Internet
I lost the combination to my sentry safe serial numbers 4895857 had it for 10 year geting kida old can you help
Sentry Safe lost combination. First, find your Sentry Safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jan 29, 2010 | Sentry Fireproof Safe
Refrigerator is running too cold - won't stop until 27 degrees
I'm having the same problem. Started several days ago. What's up?
Mar 17, 2009 | GE Refrigerators
Philips flat screen TV MODEL ID 19PFL5422D/27
I bought the television less than a year ago, so I called Philips Magnavox and they asked for the serial and model numbers. Next thing I know they asked for my name and address and Philips is sending a brand new television to replace it !!! The new one should arrive in about ten days. How's that for service? I'm very happy that I bought Philips and I will do so again. So don't forget to keep all the paper work that comes with your new televisions,especially Model and Serial numbers ! Thanks for asking , Debbie Hoffman
Aug 17, 2008 | Philips Televison & Video
Computers & Internet Logo
Top PIONEERPOS Computers & Internet Experts
David Payne
David Payne
Are you a PIONEERPOS Computer and Internet Expert? Answer questions, earn points and help others
