Question about T-Mobile Wing™ Smartphone
Power on & off
When i turn my wing off & then back on again, it loads like normal but then shuts off & restarts again. it continues over & over. sometimes i have to turn it off & back on again because of the memory. i some have memory leaks.
    Problem Solver:
  • 19 Answers
I believe that Windows Mobile has some "built-in" memory leaks. But my experience with this phone is that some of the third party apps that change the appearance of the display (i.e. - SPB Mobile Shell) take up an enormous amount of memory and tends to leak severely! I suggest removing any third party apps from your phone and seeing if you still experience the issue. If so, hard reset the phone. If not, install the third party apps one at a time and let them run for a while before installing the next app to narrow down the app causing the problem.
Posted on Jun 10, 2008
My desktop PC with Intel DH61WW mother board, Intel i 3 processor, 4 GB DDR3 RAM, Windows 7 OS Intel HD Graphic S/W has auto restart problem while shutdown is attempted. The UPS power is to be switched...
Disconnect all peripherals, except keyboard, mouse and monitor. Try to start the machine in safe mode and if it comes up okay, then try to restart it into normal windows. If the problem continues, remove all but one stick of ram, and try again. if it happens again, change out the stick of ram with one of the other ones. IF this fails, and the problem still exists, try to boot from a usb drive. If it boots normally then you may have a problem in windows, and that may need a re-install.
Sep 29, 2013 | Computers & Internet
I cannot turn off the computer
Chances are, there's a program running in the background that won't let it shut down. Try closing all your programs and shutting it down. If that doesn't work, you can hold the power button down until it shuts down, or possibly remove the battery. If this problem continues occuring, try running a virus sweep and seeing if it catches anything on your system. For a good free online virus sweep, use: http://housecall.trendmicro.com/
Hope this helps!
Mar 28, 2011 | ASUS Eee 4G Notebook
My laptop keeps restarting without me touching the same thing
Boot into safe mode, allow it to boot completely. Then shutdown/restart as normal.
It should be back. If not, allow it to reboot and choose the "Last Known..." option and boot from there.
Good luck
-Carlos:
Dec 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Xbox power light blinks and freezes xbox
That flashing green light meens there is a problem with the power to you DVD drive. the power is being interrupted. ie, when you have power the welcome screen will load and when it doesn't it will shut off. you don't have continuos power. For example if you have the power cable unpluged and then plug it in with the power on the xbox will reboot. Check the wires and the port on the motherboard if all is ok you need a new drive.
Jun 24, 2009 | Microsoft Xbox 360 Console
My Toshiba Satellite A215 - S4747 won't restart
Try to do fixboot.
Boot your computer from the installation disk,Enter in to the Recovery console by pressing
"R" when prompted>type the administrator password if any or in most of the cases its Blank
so just press Enter>on command prompt type,-"fixboot">restart windows normally once done.
if "fixboot" doesn't work, follow the above steps and try "fixmbr" this time, now should be
working fine..
plz let me know if this solves your problem.
your feedback is appreciated :)
Mar 26, 2009 | Toshiba Satellite A215-S4747 Notebook
Tmobile wing frozen
Turn off your mobile and then pull out the storage card, Restart your device, it should work now !!!
Jan 10, 2009 | T-Mobile Wing™ Smartphone
I have a hp a288n desktop. It quit responding as it has done previously and it wouldn't turn off, so I turned it off by the power button. When I went to turn it back on it would not start. I have unplugged...
I've attached the steps needed to be taken if your computer does not turn off.
If you pc is turned off and you can't turn it on now, please provide me more informations like;
  • what is the color of your screen
  • what written on your screen
  • Can you see cursor blinking or arrow
  • Any error message displayed?
  • The HP or Compaq Logo Screens are Missing on Startup
  • When the pc stops responding, before or after Windows start up?
Steps below is to show you how to resolve the issue of the pc not shutting down.
Step 1: Using one anti-virus program
You only need one anti-virus program. If more than one anti-virus program is open at the same time, uninstall the extra software programs. Several virus scanning software on the same PC can create software conflicts. This is also true for multiple versions of the same anti-virus software. For example, if Norton Antivirus version five and Norton Antivirus version 2002 are both installed on the same PC, uninstall the older version (version 5 in this case). Use the following steps to remove programs:
  • In Windows XP, click Start , then Control Panel.
  • In Windows 95, 98, and Me, click Start , Settings , then Control Panel
  • Double-click Add/Remove Programs
  • Select the anti-virus software that you want to remove and click the Add/Remove button, or the Change/Remove button in Windows XP.
  • Restart the PC when the uninstaller has finished.
  • When the Windows desktop appears, restart the PC again. The PC should shut down and restart normally this time. If not, continue to the next step.
Step 2: Disabling Software that opens with Windows
For troubleshooting purposes, reduce the amount of software that opens with Windows to try and find out if a software conflict is occurring.
  • Open the Microsoft System Configuration software (Msconfig), remove the selection next to Load Startup Items , click OK , and restart the PC.
  • For more information, refer to Preventing Programs from Opening When Windows Starts .
    Restart the PC using Windows.
  • If the Windows still fails to close, continue to next step.
Step 3: Turning off all power options
Turn off all Windows power management options and shut down the PC as follows.
  • In Windows XP, click Start , Control Panel , and then Performance and Maintenance.
  • In Windows 95, 98, and Me, click Start , Settings , and then Control Panel .
  • Double-click the Power Options icon.
  • The Power Options Properties window appears.
  • Click the Power Schemes tab and change all selections under Settings for Always On power scheme to Never .
  • Click the Hibernate tab and remove the check mark from Enable hibernate support .
  • Click the OK button to accept the changes, and then restart the PC.
  • When the Windows desktop appears, restart the PC again. The PC should shut down and restart normally this time. Regardless, continue to the next Step to see if a BIOS update is available.
Step 4: Upgrading the BIOS
The BIOS is code that the PC uses at start up and is responsible for many things. One of those things is power management, which can get in the way of the shutdown process.
Please rate my solution.
Dec 15, 2008 | Computers & Internet
Power on/off
One of the issues your probably having is your charger port might be damaged or you need a new battery. I recently had a power problem like yours and ended up getting a weird screen telling me that my phone lost power and failed to reload, to make a long story short my charger port was broken and it needed to be sent in to be fixed. I hope you have insurance because if you don't, your going to have to purchase a new phone all together.
Good Luck!
Jun 02, 2008 | T-Mobile Wing™ Smartphone
Connection to gogear
Sounds like the firmware is corrupt.
Try this:
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 27, 2008 | Philips GOGEAR SA6045 MP3 Player
T-Mobile Wing™ Smartphone Logo
67 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
