Question about Xerox WorkCentre Pro 215 Printer & Copier w/ Document Feeder & Duplex Copying
Xerox grinding noise
I have a xerox copier and it is making loud grinding noises. this only occurs whenever the copier is first turn on and when making copies. it works ok except for the annoying, loud noise.
  • 2 more comments
  • Phoenix0 Jun 02, 2008
    is there any way to know which of the two parts you mentioned is the one is not working.now changing the bearing or will the whole motor needs to be replaced.what is the rotating path is it or part or several parts.
    xerox worcentre 215 is making grinding noise. this only occurs when making copies or when copier is first turn on.i have tried to reset several things but is not working.
  • Phoenix0 Jun 03, 2008
    is pretty hard to say exactly where the noise comes from but it comes most likely from where the main motor is. if it is roller what thew name of it.
    yes i removed panels and sound comes from the area where the main motor and gears are.
  • 3,037 Answers
Have you narrowed down the exact area where this noise is coming from. It is most likely from a gear or roller. Try opening and possibly removing the outer panels and find the exact location of this noise. Tell me what is causing the noise and I can let you know what to exactly do to fix this. No amount of reseting will fix this. good luck and please let me know if you have any further questions
Posted on Jun 02, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 03, 2008
    there are more than one rollers in the machine but usually they have roller in the name. Have you removed some outer panels to get to the sound
  • Benjamin Patri
    well, start removing rollers one at a time until you find the one that makes the grinding noise, also look for loose objects or missing gear teeth
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • 796 Answers
The bearing on the motor or the rotating path must have damaged..
replace them
  • isaac johny
    isaac johny Jun 02, 2008
    first the faulty section need to be found...
    for that the printer should be dismantled first
    as i said the motor has bearings and the roller has teeth like structures which could be broken..
    the grinding noise could be either from the motor or the roller
  • Xerox Master
  • 13,433 Answers
It can only be caused by a faulty or failing part inside the printer.
  • Ekse Jun 02, 2008
    reseting the printer wont' help.
What is the cause and solution of a loud grinding noise coming from a xerox workcentre 6605 when printing
Sometimes when the toners get low on toner you will hear the gears grinding, or if there is an obstruction in the waste toner auger. Also check the drum units to make sure they are turning freely.
May 16, 2014 | Xerox WorkCentre 6605/DN Color Laser...
Clicking noise was occurring from driver side while turning.
Possible drive axle came apart, jack up front end with safety stands, pull wheel off and inspect drive axle and related components; brakes, wheel bearing, etc...
Feb 22, 2014 | Cars & Trucks
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Phaser 8570 makes grinding noise
Our Xerox 8580DN is making a grinding noise when starting up and then it doesn't start up it state that there's a jam.
Mar 12, 2013 | XEROX - COLOR PRINTERS COLORQUBE 8570/N...
My xerox machine is making really loud funny noise that are unusual, it makes the noise while it is warming up and until it prints, it is out of the ordernary sounds that we hear from it. it is more of a...
could be a few things... take out the drum and make sure the toner is put back in. then keep the right side door open and push the silver metal flap down near the back of the door opening (its the interlock that tells the machine the right side door is closed) and see if the noise occurs. if it does then you no its not the drum. so u can reinstall it. try to pin point the source of the sound with the right side door open. could be one of the many gears in back or the fuser (which is above the green colored drum) 4 screws and one wire harness takes off the fuser and u can physically inspect to see if the gears are missing any teeth or the bushings are broken. if all looks well then reinstall turn machine around and take off the back cover (6 screws) wiggle it off and turn the machine on and look closely at all the gears on the left(looking at the back) top side. when it starts it warm up process check to see if any gears are making the sound or cracked. if those gears are shot u mught need a new main drive assembly which is really difficult and time consuming to repair.
Jan 17, 2011 | Xerox WorkCenter 4150 Black and White...
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Not printing from tray 2.
Check that the paper pickup rollers forthat tray are not melted from excessive heat. Take out the paper tray and try to manually move the gears.
Sep 28, 2007 | Xerox DocuPrint N4525DX Printer
1,233 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
