I have a sony str-av460 receiver that hasn't been used for years. I plugged it in and it is flashing "protector" in red. None of the buttons operate. Is it fixable? Thanks, Tom
4 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: flashing protector code 22
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
SOURCE: STR DE435 PROTECTOR STR DE435
I have the same problemwith mine. the protector sign is on- I do not know why- and do not know what to do about it. Let meknow if you do or if you get assistance and I will do the same. My e-mail address is 1971CJS@Bellsouth.net
Posted on Feb 28, 2008
petraman7
  • 1175 Answers
SOURCE: My SONY STR-DE835 receiver amplifier is showing
These models are known for this issue.
I've had my share in the shop here.
Disconnect all speakers,turn speakers off, try headphones only
If it still persists then there is either :
1. power supply capacitors gone bad or 2. The thermal fuse in the transformer is open.
A tech can very easily find out if the thermal fuse is open by checking the primary of the transformer
if the plastic is shrinking away from the power supply capacitors then they've gone bad
Posted on Aug 26, 2010
Sony receiver str-De605 protector flashing
try a reset on unit but unit may have a faulty pa stage
Nov 09, 2014 | Sony STR-DE605 Receiver
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Sep 21, 2007 | Sony STR-GX800ES Receiver
Sony receiver STR-AV460 stuck in standby mode and don't have remote to change it. Not sure how in got switched to standby mode, but need to get it out of this mode.
Try to unplug the AC cable from the wall for a while. However this may erase some recent programming, despite Sony AV receivers have memory enough to keep programs. Hope this may help.
Sep 08, 2010 | Sony Audio Players & Recorders
Hello. my sony receiver is flashing protector mode and no sound is coming out. how do I fix this? thanks, Suzanne
More than likly the built in amplifier is dead and its time to lay it to rest. Before you do that, make sure all your positive and negitives are correct and that none of the wires are touching one another.
Jul 24, 2009 | Sony STR-DE705 Receiver
Sony str-DE435 Flash Protector
this is not a reset problem, you have a defective audio output, is either the outputs transistors or the drivers IC's ( integrated circuit) and sometimes if you are lucky is just loose connections on the drivers IC;s.
good luck
Jun 18, 2009 | Sony STR-DE435 Receiver
"PROTECT"flashing, no response, STR-SE391
The audio amplifier IC are fried and need to be replaced
Feb 06, 2009 | Audio Players & Recorders
The protector light starts flashing every time I try to use my sony tuner.
My protector light flashes on and off, whats up with the reciever ?
Jun 22, 2008 | Sony STR-GX700ES
220 people viewed this question
 Grubhead
Grubhead
