Over time, water deposits get caught in the faucet where the water comes out. You simply unscrew the tip of the faucet and rinse out the deposits. Then screw the tip back on..
If you need further help, send the model # of your faucet.
Good Luck!
Jim
Have you remove the aerator off the end of the faucet and cleaned it. More than likely it is partially clogged with deposits. It may also have a water saver washer inside the aerator. It will be a white or black washer with a single hole in it. Try removing that to see if it helps the pressure.
My pull out end has two aerators-one for a steady stream and one for a sprayer (they are selected by a swing lever on top of the end). I removed both aerators , cleaned and replaced with the same low water flow results. Even with both aerators removed the flow was very weak.
I don't know if you got my last comments, so I'll try again.
My pull out kitchen faucet has two aerators, one for regular flow and one for a sprayer. They are selected by an arm on top of the end. I removed both aerators, cleaned and replaced andd still had very low flow. Even with both aerators removed the water flow was very low out either port.
