Question about Sony UPDR150 Thermal Photo Printer
Scratch on print
I have a scratch (actually small white squigly lines) that appears on some prints but not all and it appears in random loacations not in the same area on each print. I have not been able to determine the source.
Sounds like dust within the front compartment. Remove the ribbon AND the paper roll. Give the unit a blow out with compressed air. Also wipe the print head with an alchol wipe.
Posted on Mar 21, 2009
C5800 printing vertical lines through pictures
The thin lines are caused by a worn out drum. Remove each drum in turn and look at the surface. It maybe hard to see the scratches and if so then send solid blocks of the primary colours one at a time and that will prove which drum is at fault.
Oct 28, 2017 | OKI C5800Ldn Led Printer
Minolta di200f
Mam/sir
does this line appear if you put the original on the big glass and make a copy? If not then when you use the document feeder you do not use the big glass, you use the small glass check the small glass for dirt etc. and clean it. DO you print to this machine are prints OK? then narrows the field down. IF the line appears using the big glass check the image unit or the fuser the hot part can open the right door open the hot part Wait to let it cool down check that neither fuser roller has a scratch or line on it. for the image unit try to print and stop the machine by open the right door to try to catch the paper before it goes thru the hot part does you line appear if so image unit is bad .
Apr 18, 2012 | Minolta - DI200F Printer
Line is appearing on the printed copies. How to
Is it a white or black line?There can be a piece of paper in the drum cartridge or the drum is damaged!Scratched!Try replacing the drum cartridge!Good Luck!
Dec 07, 2010 | Laser Canon imageCLASS 8180C Multifunction...
My datacard group SP75 color is printing cards with a white line all across it_
First, try to determine if it is printing a white line, or if an obstruction is possibly scratching the card surface; if it is an actual white line, then you probably have a pixel out in your printhead. Your printhead must be replaced.
Apr 15, 2010 | Datacard Group SP75 Color Card Printer
Problem with vertical white line on HP laserjet 1020 printer.
there is probably toner on the laser. take a small vacuum cleaner and vacuum out the printer. DO NOT blow out the printer as it may scratch the mirror on the laser. Also take a cloth and some rubbing alcohol and wipe off all the visible surfaces inside the printer.
Mar 19, 2009 | HP LaserJet 5p Printer
White dots on print line
At first glance it sounds like it may be a bad cartridge or toner. Try a new one. If that does not fix issue then it may be the fuser, or dirty scanner mirrors.
Feb 11, 2009 | Brother HL 2140 Laser Printer
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Video has squigly lines in it at the top of screen ..
Small board called a hyper module bad .....can be rebuilt be
skilled tech or sent for rebuild..........................T.
Jan 10, 2008 | Toshiba 50H13 50" Rear Projection...
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Oct 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Sony UPDR150 Thermal Photo Printer Logo
237 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
