Question about Samsung HL-R5656W 56" DLP HDTV
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
  • Samsung Master
  • 8,457 Answers
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Posted on Oct 14, 2010
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
My 2004 Envoy (89,000 miles)recenty started making a sound that appears to be Auto Transmission related. it shifts in the lower gears fine but when third gear shift there is a slight vibration in the...
A transmission problem would not make the steering wheel vibrate. Have you ever had the Transfer Case fluid changed? This is required every 50K miles. A qualified transmission technician should evaluate your problem.
May 15, 2010 | 2004 GMC Envoy
My volvo is vibrating and making a humming sound.
may need an e.t.m cleanout and e.t.m breather cleanout most good mechanics can do this. you dont need to replace anything.
Mar 11, 2010 | 2000 Volvo V70
Hp md5820n when is about to turn on it make a weird sound and then both red lights are flashing, i already have replace the lamp
If it loud humming noise when you turn it on - touch the side of the TV. If it's vibrating enough for you to feel it - you have problem with color wheel. It could be separate replaceable part or it could be integrated part of optical engine.
If you hear buzzing sound that goes off and then back on couple of times - could be bad lamp (even new one), bad connection between lamp and ballast (lamp power supply), or bad ballast.
If you have to replace optical engine and you out of the warranty - don't bother with repair. It would be not less than $600-$800. Invest in new TV.
Mar 10, 2010 | HP Pavilion MD5020N 50" DLP HDTV
Samsung HLP4663WX/XAA picture went out, started making strange noise, all lights on power button came on.
Sounds likea bad color wheel to me, or possibly a lamp has blown. If the noise is a humming sound--it is the CW--if you hear a "sound like a sizzle, for a few seconds and then normal, and this repeats a few times--the lamp has blown.
Oct 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Mitsubishi hd 1080 tv humming and blurred words/ bight colors
check the capasitor near the plyback value 250 volts and also the B+ capasitor
Oct 01, 2008 | Mitsubishi WS-55807 TV
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Samsung HL-R5656W 56" DLP HDTV Logo
129 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
