Question about Poulan Pro Chain Saw 46cc 20"
Poulan chainsaw 295 overheats after three minutes of cutting. Then it stops. I will start after some 45 minutes or one hour. thank You.
5 Suggested Answers
  • 211 Answers
SOURCE: Poulan 295 chainsaw won't start when warm
Hi
Check the spark plug first (when the engine has warmed and died).If you have a good spark,check the fuel pump from the carb(it shuld not to be tighten).If everything is ok check the seals(they are sealing the engine).Good luck!
savumihai71
Posted on Dec 11, 2008
Editor925
  • 285 Answers
SOURCE: I have a poulan 2150 chainsaw and the chain never
Firstly consult your manual regarding carburettor settings. There should be a high and low speed adjustment on the saw, often called or labeled as "L" and "H".
These are often located on the main motor body, closer to the handle on one side and require a screwdriver or similar to adjust. They might be buried and you have to look down the adjustment holes in the outer body to see the screws.
Basically you need to adjust the "L" or low idle screw.
Firstly, warm up the chainsaw and allow it to get up to temperature... The blade, as you say will probably be spinning still with hands off the throttle... Grab your screwdriver and adjust the "L" or low idle screw turning it counter-clockwise (at least on most saws) very slowly until the chain just stops turning on the bar. If you go to far you may stall the motor. You just want the chain to have just stopped moving on the bar, and that is your "L" setting position...
Has to be done with a warm engine though.
Please rate this solution on FixYa!
Thanks.
Posted on Apr 01, 2009
  • 708 Answers
SOURCE: POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Posted on Apr 07, 2009
  • 4088 Answers
SOURCE: Poulan Pro 295 46cc chainsaw that won't start
Does the spark plug get wet with fuel when pulled through? If dry, try spraying a little starting fluid in the plug hole and reinstall the plug. If it pops at least once, you have fuel delivery problems--look for hardened/ cracked fuel lines. Clean the muffler arrestor screen. When the muffler is off, check the condition of the piston skirt and cylinder wall for deep scoring or obvious wear. Make sure the primer button (if equipped) is filling with fuel when pumped a few times. If it doesn't, make sure the bulb is not hard or cracked and check the lines going to and from it. Check the carburetor bolts and nuts for tightness. The fuel filter in the tank could be plugged, fish it out and check. If you have checked all these items, it may be time to clean and rekit the carburetor. Hope this helps!
Posted on Mar 08, 2010
Saw quits after cutting wood for about 5 minutes
Are you sure you have the correct amount of 2-stroke oil mixed in the gas? It sounds like it is overheating. Also check the engine to make sure the fins aren't clogged with wood shavings.
Mar 29, 2014 | Poulan PP3516
Need diagram how to reinstall carburator on poulan 295 pro chainsaw
partstree.com or jacksmallengines.com I dont know if there ever was a service manual. I havent seen one
Mar 25, 2014 | Garden
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan Pro 295 20 " chain saw that wont start.No spark from plug.Think the magneto is bad. Model no.952-051310 . Need opinion and part no. Thanks.
Do a basic test first, remove the top cover, pull the earth cut out wire from the terminal on the ignition unit ( this will iliminate any problems with the switch, or wires ) now try for a spark, remember that they work off speed of rotation so give it a good pull, make sure you use a good clean plug, well earthed against the cylinder. If there is still no spark, you will need to replace the unit, part no. 530039143
Feb 17, 2011 | Poulan Pro Chain Saw 46cc 20"
I was cutting 16" logs
The motor is locked up.What it did is seized the rod too the crank.Hate to say it but it,s time for a new saw.
Nov 29, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Won't start
I have a poulan pro 295. Can't get it to fire. I've replaced the plug, and ignition coil. cleaned the entire chainsaw.
Nov 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 295 Pro won't start. Changed gas and
I suspect the carburetor is full of remnants of the same fluids you found in the tank. If it was my saw I'd take it to the local Stihl dealer for an estimate to repair. I'd expect to pay $40 - 80 for a tune up and repair depending on how many fuel hoses must be replaced. HTH
Lou
Oct 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Hi
savumihai71
Dec 11, 2008 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
844 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
