Sansui portable 14 inch tv
Sir
I have press the lock key of your remot control of 14 inch tv,now tv has locked, if i am pressing any key the screen is showing sorry...........tv locked
Service mode code
Posted on May 19, 2011
Smps short
Posted on Mar 14, 2014
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I have a red key on bottom left side of screen. Have volume but no picture. None of the controls work on tv or remote.
Hello
Your TV is locked.
The Child Lock feature prevents unauthorized viewing of the
television. To activate, press and hold the Function key, and then
press MUTE. you should see a key symbol appear on the screen.
This will lock out all remote functions (except for Standby). To unlock
the TV, press and hold the Function key and press MUTE. This will
unlock the TV. Please note that the only way to activate or deactivate
the Child lock feature is via remote control - please insure that it is
stored securely.
Jul 11, 2011 | Apex Digital AT1314DV 13 in. TV/DVD Combo
I accidently locked my citizen tv and I can't access any buttons
Front Panel Lock
This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock
feature is ON, the TV operates with the remote control.
• To lock the buttons on the front of the TV, make sure the TV is turned ON, then press and
hold the ON•OFF button on the remote for approximately 5 seconds.
• To turn off the front panel lock, make sure the TV is OFF, then press and hold the
ON•OFF button on the remote for approximately 5 seconds. Now the buttons will operate
properly.
http://support.ttetech.com/RCATV/Assets/pdfs/E13320_1558177E_IB_e-02.pdf A manual for a similar model if you need it. Many of the controls should work the same. Good luck and please leave feedback!
Oct 10, 2010 | RCA E13309 13-Inch Diagonal XL-100¿...
My apex tv model AT2708S is locked and i can't find manual
CHILD LOCK The Child Lock feature prevents unauthorized viewing of the TV. To activate, press and hold the F key, and then press MUTE. You should see a key symbol appear on the screen. This will lock out all remote functions (except for Standby). To unlock the TV, press and hold the F key and press MUTE. This will unlock the TV. Please note that the only way to activate or deactivate the Child Lock feature is via remote control - please insure that it is stored securely.
Aug 20, 2010 | Apex Digital AT2708S 27" TV
Lost codes
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Jul 24, 2009 | Televison & Video
Need code for Sansui TV
sansui: 1929, 1911, 1904
or use the general programming tool:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Mar 31, 2009 | Radio Shack 15-2142 Remote Control
HELP ME PLEASE.............
Make sure Closed-Caption is turned off.
Turn set on.
Set Volume to Minimum.
Press both Volume down on the set, and #0 button on the remote.
V-Chip password should now be released.
Bill
Mar 31, 2008 | Sansui H TV2600 TV
Unlock childlock sansui sv-t21pa2s
hi
how to open child lock for this sansui tv
Feb 29, 2008 | Sansui DTV2760 27" TV
No code
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Oct 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
275 people viewed this question
Top Televison & Video Experts
Electro Med Services...
