Question about Genie Company Genie Excelerator Down Limit Switch Part 33950s
Genie Company Genie Excelerator Up Limit Switch
My friend has a bad Genie garage door opener down limit switch (Door goes down and right back up again). Limit switch is made by Tane with part No.'s on it: FM-102BR-138 and 33969B. Would Limit Switch...
This is the close limit sensor so yes it should work. They have them for $2.40 right now from an Amazon vendor - http://www.amazon.com/Genie-Excelerator-Close-Switch-33950S/dp/B00283OBXY/ref=?ie=UTF8&m=A1CTO3U79X1RZ3
You can also buy replacement sensors as a 10 pack in case you end up needing more from here -
http://dpcdist.com/flangemountcontactandmagnetendleads.aspx
Sep 16, 2011 | Genie Company Genie Excelerator Down Limit...
IS the down limit switch # 3395OS the replacement for the #33969B ?
Yes the 33950s is the correct part number for the down limt on an Excelerator model.
Feb 20, 2011 | Genie Company Genie Excelerator Down Limit...
Genie excell garage door open's sooo slow and then stops 3/4 of the way up. Wom't move when instructed to close DOWN. Blinks 7 times in green on indicator light- so Can I trust that it is the Limit Switch...
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4. After checking those things, there is a "up force" and "down force" adjustment on the opener, try increasing the "up force" by turning the adjustment in the direction of MORE force.
Gary
Jan 07, 2011 | Genie Company Genie Excelerator Down Limit...
My garage door opener a genie excelerator all of the sudden it will no longer reconize a remote, I have tried the reset button, and it is still not working. The light doesn't blink showing its receiving a...
The problem is that the logic board has gone bad. If you don't have a logic board 900 joules or higher on these units get some. You can get a replacement board at genie.com. Thanks BB
Aug 18, 2010 | Genie Company Genie Excelerator Down Limit...
Cant get the 2 light bulb on my genie excelerator lights up during opening and closing the garage door. what can be the problem???Please help me..
If both will not light then you will need to replace the logic board because it is very unlikely both of them have failed at the same time. If it is one, make sure the lead at the bottom of the socket is pulled far enough up to make contact with the bulb, you can replace the socket itself as well. Parts can be ordered at genie.com.
Apr 23, 2010 | Genie Company Genie Excelerator Down Limit...
Genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
Jan 21, 2010 | Genie Company Genie PowerLift Excelerator...
Garage Door stuck open
IT COULD BE THE SAFETY EYES.
ARE THEY ALIGNED? BOTH LED'S LIT?
YOU MAY HAVE A CABLE OFF OR BENT TRACK.
IS THE SENSITIVITY SET TOO LIGHT?
IF YOU CAN'T SEE A PROBLEM, I WOULD CONSIDER CALLING A PRO THEY CAN NORMALLY FIX A MINOR PROBLEM FOR UNDER $ 100.00. CALL THEM. GIVE THEM A DESCRIPTION OF YOUR PROBLEM. ANSWER A FEW QUESTIONS FOR THEM AND GET A PHONE QUOTE
HOPE THIS HELPS
Dec 24, 2009 | Genie Company Genie Excelerator Down Limit...
Genie excelerator wants to run all the time
You need to check the limit switch. It is above the rail. Figure out if it wants to up too fr or down and look at that one. There is a press on connector that can come off or break. If it is broken solder or replace it. Thanks BB
Dec 20, 2009 | Genie Company Genie Excelerator Down Limit...
Genie garage door won't shut. the down limit switch wire (brown) got caught and I had to reconnect...stripped and twisted wires (just the brown down switch wire) together ... door still won't shut , it...
You don't say which model you have, however, MOST Genie systems use the switches as temporary contacts. By twisting them together, the computer board is reading it as a short. You need to replace the switch and route the wires properly.
Nov 21, 2009 | Genie Company Genie Excelerator Down Limit...
Genie Company Genie Excelerator Down Limit Switch Part 33950s Logo
716 people viewed this question
Top Genie Company Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Genie Company Electrical Supply Expert? Answer questions, earn points and help others
