Question about Health & Beauty
Manual for battery bike called electroped - Health & Beauty
I have a Proform SR 30 recumbent bike and I need to replace the batteries that show the various modes. I can't find the battery compartment.
https://support.proform.com/parts-manuals/#bikes
Go to the above page and enter your bike information. You should be able to download an owner's manual AND....there is a 1-800 number to call for support.
Semper Fi,
Z
Jan 29, 2018 | Proform Exercise & Fitness
My computer on my 900xl does not show working but is on
Unless one can reset the computer to this exercise bike by taking a battery out and leaving it out for a few minutes, then putting it back in, I have no further suggestions. There is a year warranty on the bike and the user guide offers a number to call for replacement parts (of which I presume the computer might be one). But then you would face installation and without a service manual, a lack of guidance unless there would be some from the support number. Before you make any call, see if you can locate a part number in the manual as well as the model number of the bike. Attached is a link to a manual which may be downloaded.
http://img1.wfrcdn.com/docresources/11051/15/159930.pdf
Jan 05, 2018 | Computers & Internet
Need a manual for electroped t/c bike
Contact someone who sells them, such as:
http://www.pedalandpower.com/electroped.htm or just Google "Electroped bike"
Sep 18, 2017 | Cycling
Charging problem
There is a thing called a bridge rectifier. It clips 1/2 of the AC power coming from the alternator. It makes the battery think it is getting DC - it is actually rectified AC. If there is a bad diode in the bridge, your battery will not charge. Test with a flash light battery and lamp. Good will pass power in one direction but not the other. If you can get the light to work in both directions, there is a bad diode.
May 08, 2013 | 1988 Suzuki GSX 1100 F (Katana)
Yamaha V Star 1300 error code 12 How do I fix it?
I had error code 12 today. I checked each area the manual called for but...
  • It ended up being the battery.
  • The manual makes no mention of this check, so I suggest check this first.
  • How old is your battery?
  • Check the voltage before and after since if you hit the starter button you should see significant voltage drop.
  • Moreover, put a jump on it, turn the key and hit the starter.
  • Not only did the bike crank, but the error code went away and the meter operated normally.
  • Would have saved me disassembling part of the bike to check electrical out and would have got me back on the road sooner.
Aug 15, 2011 | 2007 Yamaha V Star 1300
The battery and battery box fell off the bike while being trailered to me. what i have is a mess of wiring hanging out the left side under the seat. I was hoping a wiring schematic might help me figure out...
ive owned 4 intruders over the years they are great bikes, your best bet at this point is to buy a repair manual, they can be obtained by calling J&P cycles 800-318-6847, have them send you a catalog, lots of cool stuff!! have fun, ride safe
Feb 25, 2011 | 1995 Suzuki VS 800 Intruder
Bike won't start clicking fromsoleniod when i try. I believe it's the starter. How do I remove the starter
Not yet, that particular bike takes a very strong battery to start it. Remove the battery and take it to an automotive parts house. They'll usually test the battery at no charge. If you have to replace the battery, I the Yuasa Yumacron battery is the only battery made for that bike. It's called a "T" battery because of the preculiar shape of the battery on the bottom.
Mar 30, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Apr 02, 2009 | Cycling
Health & Beauty Logo
162 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
