I have a SAMSUNG SK01, 42" LCD. It starts and working good, fore first 10 minuts, and that it turns off
SOURCE: My Samsung SK01 42" TV
Power board assy' is defective. Check those bulging caps right into secondary circuit.
Posted on Jun 08, 2011
2coolrick
  • 560 Answers
SOURCE: I have a Sanyo LCD-32CA9S. Turns off after 10 minutes
Tru using your remote to access the factory reset mode to default. It might be hard to find, but it should be listed in your tools or settings options somewhere. Also, you can unplug the set for 5 minutes and then plug it in again. This resets the computer in several models. It's like a hard reboot.
Posted on Jul 31, 2009
  • 11800 Answers
SOURCE: Hi, my Samsung 40" LCD TV's
Actually no board/part is defective - you have a bad contact that when the tv heats up it fails. Since the screen goes totally black but not light goes out on the tv and the sound still goes on then the problem is in the mainboard or the connection between the mainboard and the t-con board - a wide flat cable.
You must open the tv and reseat the connecting cables. If this doesn't fix it then the problem is in a soldering: you will have to remove the boards and check by eye every single soldering - redo all that look suspicious; you will probably have to move the components with your fingers to clearly see a bad soldering in their pins.
Posted on Nov 02, 2010
welcomejee
  • 10594 Answers
SOURCE: SAMSUNG 46 LCD SLOW TURNING ON CLICKS ON AND OFF
It seems problem with power supply board as there are few electrolytic capacitors in output section that would be leaky/ dried up, replace them to solve your tv problem.
Please note, if you are handy with electronics stuff repair and an replace parts in circuit board then can attempt to do it yourself because it requires soldering work with proper tools OR call local tv repairman to do this job for you.
Check following image of power supply board of Samsung LN40A450, capacitors have been marked that needs to be replaced.
Hope these info will help you.
Thanks.
Posted on Nov 30, 2010
  • 19 Answers
SOURCE: my LG 42" LCD turns
first your going to need to disconnect any wires from the tv. then unplug the tv from its powersource (ex- outlet) then make sure no power is still stored within its capacitor by pressing the power button for five seconds. then lay down a plastic mat underneath the tv. then your going to need a phillips head screw driver, an allen wrench and a small rubber hammer. turn the tv around and using the screw driver remove the screws from the back of the tv, on your particular tv i believe there are 12 screws in all. carefully remove the back panel of the tv. then using the allen wrench unscrew all of the screws that hold the boards and electrical components to the front panel of the tv. remove all components from the tv. (they should all come out as one entity) now take all of the components and place on the plastic mat you have previously placed on the floor. take the rubber mallet and beat the **** out of the components and the board. once it is in snickers fun size pieces replace back onto the front panel. then carefully (without damaging any parts) put the back panel of the tv on and put the 12 screws back in place. carefully wrap the entire television in bubble wrap and personally take back to the store and order the store supervisor to refund your purchase. he will inspect the tv and showing what a horrible job that the mexicans did at the assembly facility, he will gladly give you another LG 42" and an HDMI cable for your troubles...
no, honestly go to the options menu on the tv, check o make sure its not on a sleep timer or stand by mode, if the tv has been dropped, either by you our the store in which you purchased it, it could have moved a small coil that tells the tv to turn off (makes the tv think its over-heating once it reaches a small temperature) or simply call the manufacturer and ask wtf is up.
Posted on Dec 22, 2010
TV runs 10-15 minutes. No sound. Turn off and turn on the sound starts to work. Any inputs TV, AV, HDMI. The speakers are good, headphones do not work when there is no sound.
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Mar 16, 2016 | Samsung LN-S3241D 32 in.LCD HDTV
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
The screen on my samsung ln46a550 lcd tv is dark on the right side when I first turn it on. After about 5 to 10 minutes the right half brightens up. I also have a 3
Bad news, the LCD panel in your tv is going bad, call Samsung and complain about the problem, it is a manufacturing defect. It would cost more than a new TV to replace the "panel" or LCD screen. Good luck.
Jul 24, 2011 | Samsung Televison & Video
Good afternoon. I have an LCD . When I turn it
Sometimes LCD screens can flicker if kept in cold environments. Make sure that it's not too cold in the area of the LCD. Also, make sure the cable to the monitor is connected properly, as a loose cable can also cause the screen to flicker.
Mar 05, 2011 | Samsung Computers & Internet
SAMSUNG 46 LCD SLOW TURNING ON CLICKS ON AND OFF SEVERIAL TIMES BE FORE COMMING ON SEVERAL MINUTES and geting slower ANY HELP PLEASE
Thanks.
Nov 30, 2010 | Samsung LN40A450 LCD TV
My Samsung LE40R73BD 40 in. HDTV-Ready LCD Television does not seem to start correctly, now just tries to turn it self on clicking constantly. What is the answer to resolve this
Are you convinced that all cables are correctly connected, also to the electricity. The scart cable(s) are properly in place.
Try to turn the TV off the next time it shows a mind of its own. Disconnect it from the electricity, turn off any extra units that could be attatched to it. Let the TV rest for ,2-10 minutes suit my appliances well. Then start with cables and connections in reverse order. This has oftrn worked for me I havebecome more patient as the years goby.
Jun 16, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My lcd samsung doesn't comeon when I turned it on. It clicks for about 5 minutes.
Replace the bubbled caps in the power supply. They are rated at 2200 uf 10 vdc or so. Replace with a higher voltage and you'll be good. I've up to 5 caps bubble up.
Dec 15, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
