Question about Vacuums
I have a Platinum B70 Cofee maker bought from Costco in June of 2010. I have set the on time, the off time, the temperature (192) and the cup size. All went well until today. Now the machine will not accept cup size. It goes to the max only, and it will NOT brew coffee, even though the window says "Ready to Brew".
  • Vacuums Master
  • 22,326 Answers
Take it back as its under warrenty ,i think it may have a problem with the electronics which could be caused by brown out or a voltage spike ,either way its no good unless the computorised panel works ,my best advice is to buy a small coffee perculator that you just stick on the gas and it only take five mins to boil one cup .All these so called electronic things are good when they work but one little thing can cook it ,just like modern cars with all the fancy electronics
Posted on Oct 14, 2010
Have eureka whirlwind + vacuum. Smells like burning rubber. Is there a belt to change?
Yes. You may have a bunch of hair or string that is binding the brush roller. CHeck that while you check the belt.
May 02, 2012 | Vacuums
I recently purchased a 2lb bread maker. But cannot find the manual or recipe book so I can use it. I brought it from QVC. Can you tell me where I can get this information. I would love to start using...
If you want to use the bread machine immediatly, boxed bread mixes from grocery stores will have generic instructions on the back of the box that can be used universally by most bread making machines. However, if you are wanting the manual and recipies to the particular machine, sometimes the place you purchased it from will allow you to photocopy one from a new one on the shelf. You would need your receipt to prove the purchase. Google Search is also an excellent way to download copies. The contact information on the box will too. In the meanwhile, if you want to make perfect bread follow this recipe BUT>>>do not use the machine for this recipe, use a large bowl to raise the dough.
4 large bread loaf pans, lightly greased with 1 teaspoon vegetable oil each. Set aside
4-6 cups+ flour
1/3 cup evaporated milk
3 2/3 cups water
1/4 cup active dry yeast
1/4 cup salad oil
1/8 cup table salt
1/6 cup sugar
Put the water and evaporated milk in a glass bowl and microwave to 120*~about 2 minutes. It should feel very warm to the touch but not as hot as a cup of hot coffee.
while microwaving, take a second very large bowl (big enough to hold a family size bag of chips)
put the salad oil, sugar, salt and yeast in and stir till mixed.
Add the very warm but NOT extremely hot milk water to the dry mixture. Use a swizzer to mix. Start adding the flour till very thick. Take swizzer out and add more flour gradually until it can't absorb more and is no longer sticking to the sides of the bowl. Shake more flour on a clean counter top and work the dough 3 minutes until smooth and not sticking to the counter. Place dough in another very large bowl. Cover with plastic wrap, place in a warm area such as the vent area of a 225* oven to rise. Punch down after double in size (about 30 minutes). Divide into 4 equal portions. Shape and place in pans. Rise 15 more minutes. Heat oven to 375* bake till golden brown on top and a finger tapping sounds hollow.
Wrap in plastic wrap when cooled slightly to keep moist. Refrigerate loaves to keep longer.
This recipe can be used for cinnamon rolls, clover leaf buns, pizza bread sticks or all 4 if you divide it up! Enjoy....I'm also a competition baker!
Sep 22, 2011 | Vacuums
I bought a Danby microwave from Costco 10/12/10. It is dying. Manufactuer's warranty runs til 6/13/2012. What do I do next?
I would suggest that your first try might be to go back to Costco and see what their returns policy is. They MAY take it back and either replace it or send it off to the manufacturer for repair. Failing that, go to the Danby site: https://www.danby.com/warranty.php?ln=USE&tip=INF You may have to register first, but having done that you should be able to log a warranty call with them directly
Aug 30, 2011 | Vacuums
I have the Platinum keurig and the water is going back into the reservoir and not into the cup??? is it beyond repair?
Are you getting a message saying to "de-scale" it may need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off, keep making partial cups & just not working properly. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir.Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This may eliminate your problem & should be done every 2-3 mths. If that doesn't solve it - your Keurig may already be too far gone. Good Luck.
Jul 09, 2011 | Vacuums
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
No suction
Could be a clog of course. Id run a coathanger or something similar through the tunnel the dirt goes up through.
Another thing is if the dirt cup and filter aren't seated right, it could stop suction.
You could take the dirt cup off, and turn the machine on, and see if there is any suction right at the motor, carefully of course. That could rule out a fan/motor issue.
Jun 11, 2011 | Hoover Platinum LiNX Cordless Stick Vacuum
My keurig cofee pot won't give me a full cup.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Apr 29, 2011 | Vacuums
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 | Vacuums
I purchased a nordic microwave popcorn maker and misplaced the directions for making the popcorn. I need to know how much popcorn to put in the bowl and amount of oil if any is to be used. I would...
The Nordicware Popcorn Popper is one that actually works in the microwave. The 3-Qt. Popper makes light and fluffy popcorn in about 4 minutes. Just place 1/2-cup of popcorn kernels in the bottom bowl and cover with the lid. No oil needed, makes up to 12 cups of popped corn. Good luck Richard
Nov 14, 2010 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
