Question about Intermatic T104R 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw
Timer is working but stops but stops at the on and off points like it don't have enough power to engage switch, timer is less then year old.
The pins push the lever.
New T-104 comes with a bit of white grease on the lever.
The lever is connected to the manual override.
Click the manual override back and forth. It should click firm and crisp.
If the manual override is sluggish or it sticks, then timer might be bad ... buy a new T-104 and snap the new insides into the box without changing out the box ... and if you bought it at the local store, then return the new timer with the old insides.
If the manual override works crisp and clean, then the clock motor may be bad.
Clock motors and Intermatic timers run for years, but the clock gears are plastic.
You can buy a T-100 series 240Volt clock motor at WW Grainger for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
I think you need a small star screwdriver to change clock motor
Finally, the main dial gears are steel. If timer is exposed to moisture and dirt, the gears can get rusty and that might cause dial to stall. Snap out the insides and clean out the dirt, spray a bit of WD-40. Turn off electricity because WD-40 is extremely flammable.
Up-vote if this information helped. Thanks for the feed back.
Posted on Oct 15, 2010
Valves don't operate
Unknown if this is new installation, or old installation that stopped working.
Clean waterway inside timer with white vinegar?
Change batteries?
Reset and reprogram timer
Most timers have 1 year limited warranty against defects in workmanship.
Expected lifespan for battery-operated water timer can be 6 months to 5 years.
There are no replacement parts.
Complicated digital timers can stop working for variety of reasons.
Buy another timer.
Copy following link to download manuals for several brands water timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Oct 06, 2012 | Orbit 57882 9 Station Super Dial...
I have lights that are on an intermatic timer and they are on all the time and I can't figure out how to turn them off.
You posted under Intermatic power pack.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Question does not give enough information.
1) If timer worked correctly before and then stopped working, then open link above for full troubleshoot help, including 5-year warranty information
2) If you cannot figure out how to program new timer, then read manual, and re-post question about any part of manual that is confusing. Expert might be able to help after receiving clear description of timer or model number and what you have done so far to fix problem.
3) If you need a manual, add model number for possible link to manual.
4) If you cannot find override switch, it is located above and to left of timer dial. Rotate switch to operate override.
5) If bulbs are burned out, then unplug power pack so it won't burn out, and then replace bulbs.
Match total wattage of bulbs to power pack wattage. Replace burned out bulbs as soon as they burn out so power pack will last many years.
6) Add a photo to your question by including link to Flickr
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 04, 2011 | Intermatic & Malibu& 300 Watt Power/Pack...
I have an Intermatic ML200RT outdoor timer. The timer moves correctly but the lights do not come on. It is less than one year old. Can it be replaced free of charge? It says it has a 5 year limited...
ML series power packs from Intermatic/Malibu have 5 year limited warranty.
Open following link for power pack troubleshoot checklist and power pack resources.
Intermatic links do not work on weekends, April 2011
Add a comment for more free help
Also take advantage of fixya expert assistance live.
Apr 28, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
The timer works but gets "stuck" when it comes to the ON time. it will continue this cycle if i force it to click past the ON time; but when it comes around the next day it sticks again.
You posted under malibu power pack.
When clock motor gets weak, it can no longer push timer dial past the trip point switch.
Right now the clock motor is overheating and will stop functioning.
This timer does not have replacement clock motor, but comes with 5-year limited warranty.
Buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
For complete troubleshoot, trippers, manuals and warranty information:
Apr 14, 2011 | Malibu ML900TW 900 watt Power Pack Timer...
Timer turns lights on for 2 seconds then shuts off ?????
Timer is malfunctioning, or trippers are worn down and don't fully push the switch over.
See it timer operates on manual override.
Buy new trippers, and/or buy cheap plug-in timer, and then set power pack to override, and plug power pack into cheap timer.
Power Pack uses 107SB189 ON tripper, and 107SB192 OFF tripper
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, links to manuals, useful links, warranties and tips:
Add a comment with your experience so others with same-similar problem can benefit.
Apr 10, 2011 | Intermatic 200W Power Pack & 12v...
Set time of day dial stopped working. the timer is less than a year old. no one touched the timer before it stopped working
1) Clock motor might be bad. Release thumb spring located inside box and tip out mechanism to read number printed on clock motor. Google search that Intermatic clock number for replacement.
2) Check circuit breaker and make sure circuit has 120Volts.
3) Contact Intermatic: They take care of their customers.
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 15, 2011 | Intermatic R8806P101C -...
Will not turn on . started filled with water then shut off and will not power up now. it still has water in machine this washer is a little over one year old .
Sounds like the timer motor didnt engage. Soon as the fill switch activates, when its full, the timer motor advances forward and starts the cycle. Since the water stops when full. Then part of the switch is working. The one that is nc at same time the one that is no engages. Try advancing the dial couple clicks into the cyckle then pull back out.
May 31, 2010 | Washing Machines
Transfomer works, timer dosent
If the timer is stopping, it could be a physical obstruction. Or it could be an electrical mis wiring so that the timer is turning itself off at that point, check the incoming wiring and see if it makes sense, and follow the diagram to see if the incoming power is definitely not on any switched terminals, they would maybe be marked with NO , NC,
May 04, 2010 | Hardware & Accessories
Timer pins for start-stop don't start or stop the lights
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
Upvote the help.
And take advantage of fixya expert assistance live.
Apr 28, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Intermatic T104R 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
167 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
