Question about Bosch Washing Machines
I have a new motor I need to install in a Bosch WFMC2100uc model but cant find any instructions or diagrams. Is there somewhere online I can get this information? Thanks!!!
  • 11,896 Answers
You can get it from partselect . com
Posted on Oct 14, 2010
I have wfmc2100uc the motor does not spin.I tested it and its in the ohms range. I plug it back in and it has 145v going to it but it doesn't work is this the right voltage
No should be no more than 120 vac.might have something caught in drum causing in to be locked up try spinning the drum by hand with unit unplugged.if it spins and motor spins with it belt should be looked at if it is in good shape and tight check you settings switch draw picture of wire locations for a reference later.unplug all wires with unit still unplugged of course ohm out settings if it is good than motor is in need of replacement.
May 18, 2014 | Bosch WFMC2100UC Nexxt Essence Washer
Where can I order a new pump for my Bosch model WFMC 2100 UC
Hi Toni from retired Englishman in SW France,
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 24, 2011 | Bosch WFMC2100UC Nexxt Essence Washer
I want to buy an owners manual. We can't find the original one. We have a Bosch nexxt Essence front loader, model WFMC2100UC/01 and the serial number is 856040083934001177. I have searched and can't...
The manual is available from Bosch. Start here: http://www.bshappliancecare.com/Bosch/ and select Check your instruction manual in section 1 (Browse online help). Then search on your model, WFMC2100UC/01 . The document is a PDF.
The direct link appears to be https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=qlho2Zacdcso0pdmdb---0XX&UMOBID=qlho21bcdcso0pdmdb---0XX but I'm not positive the link will work. Javascript links don't always translate into good URLs.
I hope this helps.
Jan 26, 2011 | Bosch Washing Machines
Won't wash
You need to check and replace the brushes in the motor if they are less than 3 or 4mm long.
Access is usually from underneath the washer, this means laying it on its side.
Mar 01, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
The wire around the rubber seal on my bosch washer
This video will show you how to change a door seal on this Bosch WFMC2100UC washing machine
Jan 01, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch wfmc2100uc is growling and squealing. seems to be a bearing somewhere. i need a service manual or parts diagram to determine how to get into the plastic drum to reach the bearings inside. is such a...
there is a bearing on the belt pully that is in the back of your tub that is probably bad. if you remove the back cover look for black greese splatter (bad sign). that is abpout a 3 hour job for an experienced Bosch technition and very expencive. to answer your question call a Bosch repairman in your area and ask for a parts breakdown of that area, they should help you out.
Dec 11, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch front load washing machine
Hi, motor cabon brushes are the most likely cause.
Dec 21, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Wfmc2100uc Bosch Washer
It could be the brushes on the motor or the belt has come off
Oct 20, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Washing Machines Logo
23 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
