Question about Craftsman Garden
Need a kohler flywheel puller for CV740 27 hp engine. where can I buy one?
bbreton
  • 437 Answers
SOURCE: need flywheel K161T tiller 7 hp kohler
Go to www.precisionope.com. Find Kohler under OEM parts.
Good Day.
Posted on Oct 07, 2009
  • 26 Answers
SOURCE: Do I need a special flywheel puller for a 2007
Hi Pat--
You don't always need a puller, but your chances of breaking things are greatly reduced if you do have one. If you're going to try to remove that flywheel without a puller, here's what usually gets me good results:
1) Remove cowls and panels as necessary until the flywheel is exposed.
2) Find 2 or 3 wooden stakes that will fit securely beneath the the flywheel. Square pieces about twelve inches long are best.
3) With the wood blocks underneath the flywheel, GENTLY pry up and down between the flywheel and the block evenly all the way around the wheel. You may have to tap the top of the flywheel with a rubber mallet.
Occassionally, some penetrating oil sprayed onto the flywheel's keyway will help make the separation. The real trick to doing this is to pry beneath the flywheel evenly all the way around it. Be patient and take your time. If in doubt, get any gear or wheel puller and, after tightening to GENTLE pressure, give the flywheel a few taps at its center with a rubber mallet. It should pop off.
Hope this helps.
Posted on Oct 07, 2010
  • 24 Answers
SOURCE: what is the gap between
It is not as critical as some think. A regular playing card works great. Place in between and tighten up the bolts, piece of cake as they say.
Posted on May 08, 2011
  • 21 Answers
SOURCE: how do you remove a flywheel, 24-025-04-S, without a flywheel puller
support engine weight below flywheel, with a center punch tap crank, after soaking with a penetrating oil.
Posted on Sep 30, 2012
Testimonial: "I just did the right thing and found a flywheel puller. Thanks for the suggestions. much appreciated! Brian"
  • 430 Answers
SOURCE: How do I remove a flywheel from an echo pb-413t? I bought a flywheel puller but it still won't budge?
It was pretty hard to get a flywheel puller on there wasnt it?
Use a brass hammer and a large flathead screwdriver. being carefull not to pry on anything but the crankcase and flywheel insert the screwdriver under the flywheel. With the hammer tap on the short cooling fins (These are tougher than the longer ones- you dont want to break off any fins) while prying up on the flywheel with the screwdriver. A few taps and it should pop loose. It doesnt require a lot of force but you need to be decisive with your blows.
Posted on Oct 15, 2012
How to adjust the points on engine have kohler cv460s -26509
Remove the flywheel with a wheel puller. Then adjust, or better yet, replace the points. Then reinstall the flywheel.
Apr 25, 2017 | Garden
Kohler command 21hp
Www.jackssmallengines.com, ebay, amazon, searspartsdirect.com, kohler any local small engine repair shop
Jul 30, 2016 | Garden
How to replace flywheel
Most flywheels are on a tapered shaft if no puller is available loosely install the nut as not to damage the shaft and put upward pressure on the flywheel and tap the shaft end. The flywheel should come off
May 05, 2014 | Craftsman Kohler Courage 26 hp 54" Garden...
Need to change flywheel on a Kohler motor CH 12.5S in a cub cadet 1230. Do I need to pull the motor
shouldn't. Just remove the blower housing and the hold down nut for the flywheel then put your flywheel puller on it and remove it
Mar 28, 2013 | Garden
Does my 2 cylinder kohler engine have a firing coil
Yes, some of them have covers that cover the coil. you may have to remove a cover or two. the best way is to locate the spark plug and then follow the spark plug wire back. most of these engines depending on the year will have the coil under the flywheel and they use a magnet to trigger and produce the spark. Again not sure the year but to remove the flywheel a puller is needed and you will have to remove cover, Most of these twin cylinder engines use two coils, one for each cylinder.
Here is a website that may be helpful in testing the coils. hope this is helpful. good day.http://www.ehow.com/how_7880826_test-coil-kohler-command.html
Mar 21, 2012 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Do I need a special flywheel puller for a 2007 Tecumseh 6.5 hp engine. I need to remove flywheei to reconnecr dround wire.
Hi Pat--
Hope this helps.
Oct 06, 2010 | Toro Garden
FLYWHEEL REMOVAL
You need a flywheel puller tool. You can rent them at most auto parts stores for a few dollars a day. Be advised that flywheels can be very hard to remove, and can come off suddenly and violently when using a puller, keep your face away.
May 04, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Igition Trouble
Hello:
The Ign Module is Usully the Coil and the Stator/Charging Coils are Located Under the Flywheel.
>>The Following is the Instruction File I Made for Removing the Flywheel from Most Mower Engines for Replacing the Flywheel Key, the Stator/Charging Coil/Magneto and the Point Set on Older Engines without Electronic Ign Coils.
>>It is the Basics and if you have a Question, Please Ask. Any Input to Make this File Better is Appreciated.
>>***Disconnect the Coil Wire from the Spark Plug. Remove the Blower Housing (metal engine cover).
>>Remove the Coil.
>>Remove the Flywheel Nut or Starter Cup (Depends on the Model).
>>Now Attach a Steering Wheel Puller to the Flywheel Using the Threaded Holes in the Flywheel.
>>Tighten the Puller.
>>Now Hit the Puller with a Hammer. Repeat this Procedure Until the Flywheel Pops Up or can be Lifted Off the Crankshaft.
>>On Some Models you Can Not Use a Puller and and the Jaws of a Standard Puller will Not Fit. On these Type Engines you can Use a Pry Bar and a Pipe Cap that is Slightly Larger than the Crankshaft. Place the Pipe Cap Over the Crankshaft to Protect it. Place the Pry Bar Under the Thick Section of the Flywheel and Pull Up Against the Flywheel.
>>**BE CAREFUL DO NOT PUT A HOLE IN THE BLOCK UNDER THE FLYWHEEL** >>Now Hit the Pipe Cap that is on the Crankshaft (covered with the Pipe Cap). Repeat the Procedure Until the Flywheel can be Lifted Off the Crankshaft.
>>*** Be Sure you have the Flywheel Torqued to the Proper Torque (I require the Model and Spec/Type Numbers Off the Engine to Provide the Proper Torque) and Set the Coil Gap to .020in..***
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 08, 2009 | Garden
Need to know how to change the points
The engine type is key here. For example if you have a tecumseh engine you will need the instructioins for that and if you have a Kohler engine the instructions will be different.
May 01, 2009 | Garden
Garden Logo
53 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
