I have a innovatek inno itouch how do i get my computer to recongnize the player i plug it into the usb port the item is not found
5 Suggested Answers
SOURCE: adding songs using widows media player
that same thing happend to me. the way u solve that is to up load the serves of the mp3 if u need more infermatoin visit my you tube acont its called Blackheart667
Posted on Dec 17, 2008
SOURCE: How do You download video into the Innovatek Inno - 89 MP4 Player? Please help
I have the player for my brother for christmas and had to pre-load it for him.
You have to download a program called AMV video converter.
This particular mp4 player only uses .amv movie files.
Some use .amv and .mtv but this one uses .amv and you can convert almost any movie file .mpg, .mpeg, .avi, ect... into .amv
Then just drag and drop it and play!.
Make sure you check all settings and make the video conversion big enough to see on the player.
God Bless and good luck!
Knowledge
Posted on Dec 24, 2009
  • 2973 Answers
SOURCE: i have innovatek inno itouch
Nelly, Does it have a setting to show it as a Mass Storage device? It should. Configure it to Mass Storage and connect to the pc via USB cable. It will appear in My computer as an additional drive. You can use this drive as a normal pc drive to copy/paste and drag and drop operations. Doea it have bluetooth? If yes then you can connect to the pc via bluetooth. Failing all this you can remove the memory card from the device and read it on your pc.
Posted on Oct 20, 2010
SOURCE: INNOVATEK INNO TOUCH MP3 PLAYER IMPROPERLY
Sheesh I just got two of the inno touchscreens and I can't get mine to turn on even after charging it over night only way it will come on is to hook it up into the computer or wall then it comes up the icons then straight to the blue screen to calabrate it I assume it will do the two top sides then gets stuck at the bottom left side and won't go any further, HELP ME I am ready to take these idiots for a ride
Posted on Sep 29, 2011
I did connect my Innovatek 2gigs to my computer and it dosen't charge!!!!!!!!!!!!!!
Hello there,
You can try to get another usb cable just to test if the problem is still happening. Also, try to make use of another usb port. You can also try to plug it into a different computer to be able to verify what is really causing the issue.
Apr 09, 2011 | Audio Players & Recorders
I plug my sansa E200 in my computer and nothing pops up and its not im My Computer i just want to know what i have to do to put music on it???????????
Hello:
As i see the Computer Won't Recongnize it.
Well most likely its gonna be a Problem with the USB connection:
Try to inspect one of these:
  • Drivers Not Installed/Corrupted.
  • problem with USB Cord.
  • Problem with USB porte in PC
  • Probel with USB Plug in the Mp3 Player.
Good luck
Nov 04, 2009 | SanDisk Sansa e200 MP3 Player
Computer will not recongnize coby player.
What I have seen it is should show up under the flash drives. The one thing you can try is going to the coby website and downloading the driver for the player. That should fix that your computer is not finding your player. Hope this helps.
Sep 28, 2009 | Coby MP-C741 MP3 Player
Mp3 player messed up
   Please find reset button which will present in a hole. insert some kind of pin or any thing els in the hole to press it, afterwards it work fine again.
Thanks for using fixya.
May 13, 2009 | Audio Players & Recorders
Knowledge
Apr 22, 2009 | Audio Players & Recorders
Itouch smoking
you should have a warranty through apple
Mar 21, 2009 | Apple iPod touch
On connecting the itouch to my laptop via the USB it crashes
Remove all the data from Itouch, takes about an hour. then reload using itunes. now all work fine together!
Jan 06, 2009 | Apple iPod touch
I have this problem too....
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 18, 2008 | SanDisk Sansa m230 MP3 Player
171 people viewed this question
 Grubhead
Grubhead
