Question about AOL Instant Messenger
Target rate limit reached. statusDetailCode 5 what does this mean
3 Suggested Answers
  • 10865 Answers
SOURCE: What does this mean: Target rate limit reached.
this is a glitch that aol is trying to fix. If you right click twice in the message seems to work it reloads and
teh buddy list will appear again
Posted on Nov 03, 2009
SOURCE: says I reached target rate limit?
Apparently this is some kind of AOL glitch as other people are having the same problem.
Try this: Right click on where the error message is and where the Buddy List would be. Then go to
REFRESH and click.
Cheers,
F1X3R3R
Posted on Mar 15, 2011
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check plug connections.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
What do DTC P1265
code P1265 injector 2 control limit exceeded or limit not reached.
Feb 24, 2013 | Jeep Cars & Trucks
IPhone 5 temperature limit?
The iPhone is a very durable piece of equipment; it is built to have an operating ambient temperature of 32 to 95 degrees F (0 to 35 degrees C) however it is not built to withstand temperatures of -4 to 113 degrees F (-20 to 45 degrees C)- which means you should probably think about getting a different phone.
Sep 16, 2012 | Apple iPhone 5
Says I reached target rate limit?
REFRESH and click.
Cheers,
F1X3R3R
Mar 15, 2011 | AOL Instant Messenger
Every time i try to send text or anything this appears" maximum limit of applications reached" I have deleted all photo's and videos and it tells me I am only using 5% space. how do i fix...
May be it means you have reached the maximum limit of the characters in a message. For that you need to go to your message options and change the settings to maximum limit for text messages.
Jan 24, 2011 | LG KC910 Renoir Cell Phone
Receiving target rate limit reached status detail code 5
how can i fix it it says Target rate limit reached. statusDetailCode 5
Oct 06, 2010 | AOL Instant Messenger
How do I use the Bell AirStrike Digital Floor Pump
The gauge measures three different amounts. Be certain that you have it set to PSI. Then set the target PSI. The green LED indicator will then flash when you are within 5 PSI of your target and will flash constant when the target PSI is reached.
Jan 02, 2010 | Airstrike Bell 1800 Floor Bike Pump
Nov 03, 2009 | AOL Instant Messenger
AOL Instant Messenger Logo
506 people viewed this question
Top AOL Computers & Internet Experts
Rick Moore
Rick Moore
ray gallant
Paul Chana
Are you an AOL Computer and Internet Expert? Answer questions, earn points and help others
