Question about Canon PowerShot A95 Digital Camera
My GE A1250 has gray horizional lines in the pictures. It looks fine when you take the picture, but to view, print, or download, you can see these lines. One day it worked fine and the next I had the lines. It is less than 1 yr old and has been gently used. Any help or ideas?
  • 170 Answers
See this thread on fixya:
http://www.fixya.com/support/t114938-canon_digital_camera_recall_defective
Posted on Oct 14, 2010
How can i move photos from my GE A1250 camera to my laptop? I lost the disc, my computer does not have a slot to insert the media card...can i download software from somewhere?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
If you insist on using the USB connection, Picasa should still see your camera when you connect it.
May 16, 2014 | General Electric A1250 Digital Camera
How many pictures does the A1250 camera hold
That depends on the size of the memory card and the camera's image settings. The larger the card, the more pictures will fit. The finer the image quality and size settings, the fewer pictures will fit.
For more on the camera image settings, see pages 27 and 28 of this manual.
Jan 08, 2013 | GE A1250-BK 12MP Digital Camera with 5X...
Tv 27" has only half screen picture horizional I
Possible failure of the VERTICAL SECTION of the deflection circuit. It is possible that the areas related to the vertical circuit is checked , check for weak capacitors near the output vertical drive. Also a faulty vertical coil- deflection coil- can result in half picture.
A vertical signal test can confirm.
Oct 16, 2011 | GE Televison & Video
When I initially got the camera i could, now i can not load pictures from my GE Digital camera A1250 on to my computer. Need help to troubleshoot this problem?
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 20, 2011 | General Electric A1250 Digital Camera
I have a ge a1250 and i accidently lost the cd and i have a mac and cant view pictures or anything what do i need to do
You don't need any drivers. You just have to get the USB cable, connect it to your camera and then connect it to your mac finally. No special drivers are required since most of the cameras now are you using the 2.0 mass storage and this is standard. You can also remove the memory card and directly plug it into the SD port of your Mac.
Apr 09, 2011 | General Electric A1250 Digital Camera
Can not get ge a1250 sl to download to computer using windows xp os. have used install disk
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Oct 25, 2010 | GE Cameras
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
GE model 31GT660
Is the brightness in the middle of adjust range? Is the picture
or contrast adjust at 3/4 ? Next,adjust the screen voltage on
lower rear of cabinet = one control is focus and one is screen..
how is the picture now ?..........................T.
Feb 11, 2008 | GE 31GT660 TV
Canon PowerShot A95 Digital Camera Logo
301 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
