Question about NetGear WGR614 Wireless Router
My net gear router is not connecting
I can not get my router to connect. I think I read somewhere the blue cable should be hooked in the router. I have a yellow cable going from the external modem to the router. My blue cable is going to the modem and directly to the computer. Is that correct?
  • Anonymous Jun 05, 2008
    Can not get an internet connection. recieve the following information---Error AC-3001; 0x84100118, OS WinXP-SP2; ACS, TCP/IP Connection NO IP Routes. Firewalls: Trend Micro Personal Firewall, Trend Micro PC-cillin internet Security (firewall). My laptop recieves a strong signal fron netgear and I can access the internet. Need some help Thanks, Sky
  • 144 Answers
If the yellow cable is already connected from the modem to the router, the blue cable (must be an ethernet cat 5 cable) must be connected from one of the regular LAN port of the router to the back of your computer. Ethernet card should be installed on your pc so you can connect the blue cable.
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Posted on Jun 04, 2008
I have a net gear wnr 2000 trying to hook up a wn2000rpt using the wps button and it's not workin
try it first w/o encryption to see if it will connect.
also note that SOME wireless WPS-capable equipment documentation says that it will only work with WEP-level encryption; so read your doc's and be informed. WEP can be broken in about 30-seconds with today's
Oct 21, 2014 | NetGear WNR2000 Wireless Router
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear Computers & Internet
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
I'm unable to get wireless even though I'm all hooked up with my provider via the modem and a dlink. The only difference regarding the hook up is there is no longer an ethernet cable going to my pc
check the router config settings, may be the router isisnt dialing ur net connection or if u have a static ip n stuff make sure ur default gateway and dns are proper
Jan 10, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Net gear was completely disconnected from computer. net gear WPN82r v 2 was inadvertently reset. dont have a password. any help
To bypass the wizards, connect the router via an Ethernet cable, log in from a DHCP enabled (IP & DNS) computer at
User name is admin and the password is password, both in lower case letters.
Note that wireless connectivity is off by default. When you configure this router manually , remember to turn the wireless connectivity on.
Jul 11, 2009 | NetGear RangeMax WPN824 Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes and Netgear
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
