Question about Dell Inspiron Mini 10 Notebook
I have a dell mini laptop that wont boot up the window that pops up states folling files ar missing or corrupt sence it dose not have a cd rom drive i cant reload the o.s ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
The mini computers dont have CD drive so use the following option
Dell has a default partition on the computer and you can install with the same..
If you have windows 7 on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If the restore option is not available then call up the tech support of dell(18006249896) they will replace the HDD to fix the issue
Posted on Oct 15, 2010
NTLDR missing problem
NTLDR is one of the essential files for booting up your system. If this file is corrupt or missing the computer wont simply boot. The solution here is to Get the CD for your operating system. For example Windows XP or Windows 7 etc. If you are using Windows XP, put the CD in the CD ROM and press Del or F2 to get into the BIOS of the computer. Go to the Boot Order or Boot Sequence and select the CD drive to be the first boot device and press F10 to save and exit. This will allow the XP CD to boot. On the first page after loading all the files, press enter, then you will have to press F8 to accept the Microsoft license, then you can select "R" to repair the system (This will only overwrite the contents in the C:\Windows and this will fix up your start up problem. If you are using Windows 7, boot from the CD like in XP then choose to repair your system.
Feb 22, 2012 | Dell Computers & Internet
NTLDR is missing
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file..
  5. Corrupt boot sector / master boot record.
  6. Seriously corrupted version of Windows 2000 or Windows XP.
  7. Loose or Faulty IDE/EIDE hard disk drive cable.
  8. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable CD-ROM. First verify that no CD is in the computer, unless you are attempting to boot from a CD.
Nov 29, 2011 | HP Compaq 6710b Notebook
It states windows could not start because file missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM you can attempt to repair this file by starting windows setup using the original set-up cd-rom. I did...
Check that the Bios will allow boot from cd by going into the bios and nselecting DVD drive as master or first boot device.
Re start the notebook with the disk in the drive and then it will boot from the CD. Then try again to repair your system.
Hope that helps.
Nov 20, 2010 | Dell Inspiron 6000 Notebook
Windows XP corrupted - Why can't I reload windows
You have to change the bios settings for making it boot from usb device. look at boot menu on the bios/usb cd-rom
Oct 10, 2009 | Dell Latitude C400 Notebook
\Windows\System32\Config\System; Repair w/CD-ROM; NO CD-ROM
if you can get an external cd/dvd drive from a friend, then you could solve the problem.
other solutions would mean that you will reinstall windows again. This takes more time and has a few tricks to be done from a flash drive.
Mar 22, 2009 | Acer Aspire One PC Notebook
My dell d600
NTLDR or NTDETECT Is Missing or Corrupt Error Message
Table of Contents secondary.gif Start the Recovery Console secondary.gif Repair the Missing NTLDR or NTDETECT File » Start the Recovery Console
  1. Insert the Windows XP CD into the CD or DVD drive.
  2. Restart the computer.
  3. While the computer is starting, repeatedly press F12 every 3 seconds to access the one-time boot menu.
  4. When the one-time boot menu appears, press the Down Arrow to highlight the CD-ROM option that appears, which is one of the following options: Onboard CD-ROM Drive or Onboard USB CD-ROM Drive.
  5. Press Enter.
  6. When the computer boots to the CD-ROM drive, press R to enter the Recovery Console.
» Repair the Missing NTLDR or NTDETECT File
  1. Boot the system to the Windows XP Recovery Console.
  2. Type map, and press <Enter>. Make note of the drive letter assigned to the optical (DVD or CD-ROM) drive.
  3. Type copy x:\i386\ntldr c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  4. Type copy x:\i386\ntdetect.com c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  5. If you are prompted to overwrite the file, type y, and press <Enter>.
  6. Type exit and press <Enter>.
  7. As the computer restarts, remove the Windows XP CD.
The files have been restored and the error message should be fixed.
You can check this website for further details.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=B93824605BF646F98FDFACA51E3A9B55&journalid=4F6F8BC06C3B5014E040AE0AB5E121D2&Query=TlRMRFIraXMrbWlzc2luZw==&SystemID=LAT_PNT_PM_D600&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Pls let me know asap if we did resolve it.
Dont forget to rate me Fixya....
Cheers.
Jun 15, 2008 | Dell Latitude D600 Notebook
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Boot up issues
run cmos bios and configured boot device..first boot cd rom drive..
then reinstall/repair your os...
Mar 24, 2008 | IBM ThinkPad T21 Notebook
Dell Inspiron Mini 10 Notebook Logo
151 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
