Question about Hotpoint Dishwashers
My brand new Hotpoint Ultima SDW80 keeps coming up with AL08 and stops within 10 minutes of a cycle. What does this mean?
  • 93 Answers
SOURCE: what does code al99 mean
AL99 is a communications error.
check PCB(s) cabling, connectors .
Posted on Jul 28, 2008
SOURCE: SDW60 - AL08 Error - No Hot Water
Hi fridge-1,
I had the same problem and fixed it by fitting a new control board .
Best of luck.
michael-howe
Posted on May 16, 2009
SOURCE: hotpoint ultima sdw80 45cm door
Door catch needs replacing. Can be done yourself. Top 6 or so screws removes the top section of the door and the catch is held in by 2 screws and has two easy to remove / replace.
Posted on Mar 16, 2011
FitzOriginal
  • 842 Answers
SOURCE: my hotpoint ultima FDW85 -
I believe that this means "Heater element open circuit" Symptoms are thayt the machine will fill with water but then will not wash because it's waiting for the element to start heating the water and it can't.
Posted on Jul 25, 2011
mc1bean
  • 3053 Answers
SOURCE: my hotpoint sdw80 dishwasher gets very hot around
Hello, honey
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Hotpoint ultima DW stuck on cycle does't appear to be heating either
Sounds as though you have a fault in the heating system, it could be a short in the wiring to the heater or it may be the heater itself which as fault. While the machine is waiting to heat the water it will not advance through the program
Jan 16, 2017 | Hotpoint Washing Machines
Hotpoint ultima sdw80 45cm door will not keep closed when in use still doing the wash cycle
Oct 31, 2010 | Microwave Ovens
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi fridge-1,
Best of luck.
michael-howe
May 03, 2009 | Hotpoint 24 in. FDW60 Free-standing...
HELP WAT DOES F-01 MEAN ON MY HOTPOINT ULTIMATE SUPER SILENT WF86
F01 means there is a motor triac has short circuit. areas to check are the motor, connections and module. BE VERY AWARE THAT THIS MOTOR IS A 3 PHASE ONE AND THAT YOU SHOULD UNPLUG THE MACHINE FROM THE MAIN POWER SUPPLY AT LEAST 5 MINUTES BEFOR WORKING ON IT BECAUSE THE HEAT SINK ON THE MODULE HOLDS A LIVE CURENT FOR ABOUT THIS LONG EVEN AFTER DISCONECTION
Mar 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Extra door lock will not unlock at end of cycle
could be a defective door lock. these door locks have resistance within them and with the application of power, bi-metal moves and lock the doors.
test it again by using the unit and after 10 mins and the door won't un-lock , try to knock the door switch a little bit and see if it would unlock. if it does, then it is the door lock. it is getting sticky.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dishwashers Logo
136 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
