Question about IBM 6400 Matrix Printer
Ibm 6400 Printer thin 3 copy module loading problem
I have a 6400 printer that works very well with normal paper module.
Loading paper with very 3 thin carbon copy module have problem. It's like the machine does'nt sense the paper. Any solution ? (I am not confidential with this unit). Tank you
  • 21 Answers
The 6400 paper present sensor works off the reflection of the paper itself, so if the paper you are using is black on the back the sensor cannot work as there will be no reflection. You need to remove the sensor and rotate it in its housing 90 degres so that it is facing the flag on the paper motion sensor, you may also have to paint this flag white (reflection to work) tipex is ok for this.
Posted on Sep 16, 2008
When removing the document that prints, how do I remove it from the continous paper without wasting a sheet every time?
Press the view button tear off the paper then press view button again and the printer will bring the paper back down, I think anyway
Mar 23, 2012 | IBM 6400 Matrix Printer
It pulls more than one page into the printer . is
Please check your printer's rubber roller that is responsible in pulling out the paper. Please clean it from any accumulated dirt.
Also, one important thing is that make sure that your paper is not to thin sheets preferably substance 16 and above. Also, shuffle the pages before loading to the printer tray.
Feb 06, 2010 | IBM Lexmark Z715 InkJet Printer
IBM 6400 Emulation software change
Hello !
I have a IBM 6400 printer in AS 400 system. I want to convert that printer to PC system to print daily to day printing which I can support Window XP and Windows 7.Please let me know the coorrect way to do that and what are the software I need to download.?
Mayuri
May 14, 2009 | IBM 6400-I2S Matrix Printer
Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | IBM 6400 Matrix Printer
IBM 6400-A00 prints normally and stops
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
IBM 6400-A00 PRINTS NORMALLY AND STOPS ERROR
ENTER
ROD
Dec 16, 2008 | IBM 6400 Matrix Printer
IBM 6400-A00 prints normally and stops.
Please Clean or Change the Platen Open Sensor Switch.
Your problems will be Solved.
Regards,
Pawan Dahake
( I.P.S., Nagpur )
INDIA.
Dec 10, 2008 | IBM 6400 Matrix Printer
Wont print on line
You may need to have some driver installed on your PC, that can be downloaded from some IBM printer web site, such as this one:
http://www.infoprintsolutionscompany.com/internet/wwsites.nsf/vwWebPublished/supportdownloads_ww
IBM does not manufacture printers any more, they outsourced that to other places like Lexmark & ProPrinter, so we have to figure out which outsource place is relevant & what name they have for whatever corresponds to 6400 driver.
Sep 27, 2008 | IBM 6400 Matrix Printer
IBM 6400 firmware resetting
Hold cancel+stop while powering on the printer to enter the maint menu. You can wipe the firmware from there. You need to have a copy of the microcode firmware to reload. If you are uncertain about these instructions, you absolutely should not attempt it.
Jun 18, 2008 | IBM 6400 Model 010 Matrix Printer
Small problem with SCX-4200
I have the same issue but it resolved by itself.  I turned off the printer for a night and test again, it works.
Mar 14, 2008 | Samsung SCX 4200 All-In-One Laser Printer
IBM 6400 Matrix Printer Logo
77 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
